Thoughts on this quick disconnect
Azzy5779
So 2 owners before me, the owner put a 4" lift on my 03' Tj and must have put these on. The look homemade to me. This is not a rubi, it's a sport. What do you think? Could I trust these? It doesn't help that the lift is not labeled anywhere.
I would change them out just on the rust factor, and get yourself a new set of links.. Like the Jks quicker disconnects and start fresh..
As others have mentioned I would swap them out. I don't trust that cotter pin there. Get jks as others have mentioned
That looks like an early gen Rubicon Express or Rancho link. RE has recently changed their design but I will also recommend getting some JKS links.
Those cotter pins look cheap and looks to have rubber bushings not polys.
After a second look at the picture I see what you are saying. I can't believe the pin hasn't broke yet.
Yeah I'll look into them, I thought the pin was a bit sketchy. Just wanted to get someone other than my thoughts on it. Thanks guys.
I have never used them, frankly due to the fact that I am in Iowa without any trails and because in the coming 3 or so months it will be a mall crawler.
yiiikeeess at a minimum get actual pins:
