Rancho Caught the Bug May 10, 2016 #1 Our latest glide plate is for the TJ/LJ rear Dana 44. Helps you glide over rocks and not get hung up. Check with your local retailers on pricing.
WJCO Meme King May 10, 2016 #2 Do you know if this will fit the 44a style rear axle? Also, do you have any pics of how it secures near the pinion area? EDIT: NVM, just found out the covers are completely different. Different bolt pattern. Last edited: May 10, 2016
Rancho Caught the Bug May 10, 2016 #3 So it will go over the pinion with a u-bolt. And you got it figured out. WJCO said: Do you know if this will fit the 44a style rear axle? Also, do you have any pics of how it secures near the pinion area? EDIT: NVM, just found out the covers are completely different. Different bolt pattern. Click to expand...
