Traction control keeps engaging when its not supposed to.
clayconway
I have the JSCAN app but could not find steering angle sensor anywhere. Would that be because I have a 2007 model? The clock spring was replaced by dealer last year.
I regeared it last May so the current axle ratio is set at 5.13.
I've since taken it to a specialty offroad shop and the Jeep dealer. Neither could solve the issue. The dealer scanned everything and reprogrammed it. Nothing worked. Living here in Western Colorado means I do a lot of switchbacks. It's annoying to have the traction control kicking on all the time.
Did you ever get this sorted out?
We had this happen on ours on windy days on highway due to holding the steering wheel turned to compensate for the wind.
jeeeep
dealt with this on my JKU, pretty much every time I would turn into a driveway and if I recall, it was always when making a right turn.
I was also dealing with bump steer under normal driving.
Installed a drag link flip kit, the bump steer and traction control issue went away.
Check that your drag link and track bar are parallel to each other.
