What did Brown Santa show up with today..
Evo skins are in. Just need to order some lights. Anybody know if the fuel tank door works with these or you need the open one?
Also, the top corner hole that isn't counter sunk, don't put a rivnut correct? I'm planning on getting a carrier.
Fox 2.0 Performance shocks to go with the 4" EVO plush ride coils I got in a couple weeks ago. Now I just need the weather to cooperate. 70 degrees yesterday and now this.
got my switch and housing for it along with some new lights for the floor of the rig!
Yes the fuel door still works with the corners. You may have to trim the plastic insert a little to get it to sit in the armor. Correct the non counter sunk hole is for the carrier so if you do install a rivnut you'll need to drill it out when you install the carrier.
Ok, I'll just leave that bolt out and not drilled till I get the carrier. I didn't get instructions with the corners, but I think I got this.
