tdougherty81
Small evap leak this morning. Cleared it and will see if it pops back up.
Ok where do I start 1 the top almost came off on the highway, 2 the exhaust manifold fell off, 3 the rad spring a leak , 4 the windshield cowl is leaking ,
And I just bought it this week oh and 5 one of the wheels almost fell off from PO didn't make sure they were torqued properly,
My driver side lower control arm threw its bolt on the highway so now I have to take it in to the shop that did rear end work because I'm covered under limited lifetime warranty. Not a bid deal but when I take my foot off the accelerator the rear end kicks 3 feet to the left.
Sent from my Life One X2 using WAYALIFE mobile app
When I'm at highway speed it's really bad too, I swerve all over, luckily since the lower control arms are spring tensioner it stayed in its general place instead of dropping to the ground.
I'm not anymore, I took the Jeep into scotties auto and within half an hour they had a new bolt in and retorqued the one that was still in. Believe me if I could've driven something else I would have, driving it like that was terrifying.
That's a baby crack, you could probably seal that up with some exhaust wrap until you really need to replace it. Mine cracked almost an inch wide open so you got lucky.
As a matter of fact, thats exactly what I did. If it fails, I will chip it away and use ThermoSteel. But doing good for now. Thanks for the suggestion though.That's a baby crack, you could probably seal that up with some exhaust wrap until you really need to replace it. Mine cracked almost an inch wide open so you got lucky.
Sent from my SM-N910V using WAYALIFE mobile app
