Question...
Shouldn't that joint be flipped the other way to that a rock doesn't break off the zerk fitting?
If you did that every time it needed to be greases you would have to drop the LCA's.
Sent from my fRuit product using WAL
Question...
Question...
What type paint did you use??
Before install I was thinking the same thing but no room in there to attach grease gun tube, looks deceiving but actually is aimed away quite well. For added protection I will be buying the EVO C-Gussets and Front LCA Weld on Skids very soon!
It's a high temp paint made by rustoleum. You can get it at your local Lowe's or Home Depot.
I asked same question when installing my EVO control arms on weekend. The advice was given was point them up to prevent damage. And to buy some 90 deg zerks to make it still easy to grease without dropping them.
I picked them up but didn't install them yet as I have to reinstall them. Was just doing a clearance check. I plan to do it tomorrow and can take some pictures.
Go parts with less oil burning quiet running option......
5.38's, Go faster easier parts......
Go faster with less shock parts.......
Turn in rocks upgrade with badass skid plate option.
Go parts with less oil burning quiet running option. View attachment 75527
5.38's, Go faster easier parts. View attachment 75528
Go faster with less shock parts. View attachment 75531
Turn in rocks upgrade with badass skid plate option. View attachment 75532 View attachment 75533
I approve this message :rock: The force is strong with your build young Jedi....
I really only wanted the skid but needed the other parts lol. Evo Carrier and long arm ordered. Hoping to make it to dwarf quasi Jedi wannabe by Moab.
Installed a new license plate bracket, highly customized
View attachment 75406 View attachment 75407
What's the difference with the stock one?
It wraps around the corner vs sticking out straight.
- Jason
Looks better than the stock one?
Ps.not trying to be a dickhead
Looks are like opinions. To each their own. But the point is to tuck it a bit closer to the body so it doesn't get tagged by rocks etc on the trail.
- Jason
