Cool thanks guys. I wasn't sure if it would snap now. I guess I need to do a better job at putting it away
Actually, with winch rope, you don't want to spool it nicely. The first layer should be neat and tight, then after that, you do a wild, zig zag kinda spoiling. This prevents the rope from pinching down between the previous layers and becoming wedged in tight.
With cable, you always want it perfect, and if it crosses up, you can get a kink, which can become a weak spot.
With rope, a crossed over section like you pointed out is perfectly normal and just fine. If you try to spool rope like wire, you will likely experience that your rope does not want to pull out of the drum easily- I thought something was wrong with mine for a while before realizing that it was just pinched between the other layers.
Also remember to try to keep your rope dry and out of the sunlight and it should be good for years to come. [emoji106]
![emoji.tone1 :tone1: 🏻](https://cdn.jsdelivr.net/joypixels/assets/6.5/png/unicode/64/1f3fb.png)
