Yes, it was something extra on the XR. Can be bought in sets of either front or rear.oh, the piece that extends beyond the fender...
Tire PokeWhat was wrong with the normal Rubicon ones?
What needed to be done to install these? Do existing plastic rivets come out (and are replaced) or does the mounting use some other strategy?
I would be interested in doing this if it keeps more mud off the Jeep.
You have to remove most of the existing plastic rivets and install new ones with the flares some drilling is required took me 15 minutes for all four fenders easy job!What needed to be done to install these? Do existing plastic rivets come out (and are replaced) or does the mounting use some other strategy?
I got 100 rivets same as OEM Mopar rivets for 9.99 on Amazon Jeep dealers will charge over 4 dollars per rivet!This is a listing of JUST the extensions, you would still need rivets.
Genuine Mopar Xtreme Recon Fender Flare Extensions Set Of Four - JLRECONFLAREEXT | All Mopar Parts
Shop Genuine Mopar Xtreme Recon Fender Flare Extensions Set Of Four - JLRECONFLAREEXT online. Choose All Mopar Parts for its affordable Mopar parts & save $29.43. Shop now!www.allmoparparts.com
Yeah, it's like $110 for a set of rivets to do the job through a MOPAR dealer.I got 100 rivets same as OEM Mopar rivets for 9.99 on Amazon Jeep dealers will charge over 4 dollars per rivet!
And they'll tell you the price with a straight face, not even bat an eyelid lolYeah, it's like $110 for a set of rivets to do the job through a MOPAR dealer.
