Both multi switches died at the same time
Trail Bud
I have a 07 jk that has an issue of both the turn signal and wiper switches (multi switches) on the steering column stopped working. I have no power to the signal, lights, high beams, wipers, cruse control.
Fuses are ok too
Seams weird both would die at once. Has anyone had this happen? Or are the switches tied together for power or something?
I looked around and found some information but it's not consistent with issue to issue.
Any ideas?
Thanks in advance for the advice.
Cruise control issues can be related to a bad clock spring. Maybe the clock spring failure damaged your turn signal stalk?
Thanks Eddie
I just put one on hold at my dealer for $239.00 in stock.
I'll use the write up and save the $$.
Very cool!!
Just finished the install. Clock spring removal is a bitch, like the write says your working blind.
Lights are still on but if I remember it will reset after driving.
Thanks again!
