KeroJK
So i installed my lift about 5 months ago now. It is the 10a spring swap with bilstein 5160 shocks on my 07 2dr. Netted me about 2.5 inches of lift And up until now, I have not noticed how bad my jeep rides until i got my new tires and alignment. The jeep is bumpy, inconsistent, and floaty. I assume that has to do with my control arms not centering the axle. I need perfect steering for the winter and i need your guys advice.
Should i use the infamous rancho geo bracket to recenter everything easily or should i go with a set of lower arms.
I dont want to spend the money on new upper and lower control arms, do i have to or are lowers enough?
Will the rancho bracket work good with my control arms considering i ran them like an idiot with improper caster? Or could they be worn out bad?
Thank you for helping an idiot noob!
Sorry if i need more info i posted everything I know and i determined that my caster is bad from another thread that helped me understand my alignment sheet. Wayalife is awesome
Sent from my SM-N950U using Tapatalk
