danford.lau
Damn Ed how many rigs do you have ? Anvil with the same AEV wheels I have now !
I’m currently running Cooper STTs with 4” bs (5.2 + 1.25” spacers)
Will 3.5” bs on 35s be too little ? Stick out too far ? Any concerns about stress on components?
Please post up photos if you have them . Want examples of 35s and 37s (12.5 width) . I’m eventually going to 37s and want to buy wheels once but want them to work for my 35s without looking goofy
Thanks
When I went to beadlocks I at first was running the 35" Coopers. I got Trail Ready beadlocks , 3 1/2" backspace and everything worked fine. I'm now running Nitto 37's on the same TR beadlocks.. I'm very happy with the way they are performing.
Is this while flexed out or just daily driving?I’m currently running AEV Pintler wheels with 37’s. These wheels have 5.2” backspace and I have very little rubbing on the frame at full turn with stock JKUR axles. I would think that any wheel or wheel/spacer combination of 5” backspace or less will not rub at all and believe that the less stress on steering components the better.
I’m not going to call BS on this but all I can say is I run 3.5 on my 37’s and still rub a little. *
I can certainly appreciate your skepticism. Here are a couple of pics I could find.
View attachment 319563 View attachment 319564
Yep. My wheels are 4.5" BS and I added the 1.5" for the 37s. They were fine with my 35s.Here’s a thought. I have Methods with 4.75” BS running 35’s. I already have some 1.5” spacers. I guess if I wanted to jump to 37’s I could put the spacers on when needed. Extra work but just an idea.
I notice you still have full fenders, so the rubbing must have been solved with more bump stop and adjusted steering stops.
Also doesn't look to be disco'd. I'm running 35x12.5 17 with 4" of back space on a 3" lift with 3" bump stops and would get rubbing on the fenders and front bumper before I cut them. I also get rubbing on my front lca's but I'm also on a long arm lift so that may contribute to thatThat is certainly possible. It’s a bolt on 4.5” AEV lift and since I didn’t do the install I’m not certain what specific bump stop length is being used or what adjustments to the steering stops would have been made either.
