Bear_JT
Looks good. Seems like it all worked out well for you.
Finally got the Jeep back on the road today. Replaced all the melted stuff (plastic fuel line, both vapor lines, heater hoses) and all plastic wiring loom under the hood. Changed spark plugs & wires since wires were charred a bit and both were due at 100k miles. Runs great!View attachment 325967
Awesome. Did you just fix this yourself out of pocket or did you go through insurance?
Glad you weren’t hurt. I know somebody mentioned coolant is not flammable, I used to think so too. A few years ago we had a military wrecker catch fire and burn to the ground, I was not there at the time, but on lookers said the coolant was burning. I thought that was BS. The fire investigator listed the fire as a coolant leak that was ignited from spraying on to exhaust.
This may be true in the case of military vehicles, but likely not relevant to this situation. Many military vehicles, such as those made by Oshkosh, utilize a single fluid for gear oil, engine oil, and i think coolant as well. This allows simpler maintenance in the field, but also means the coolant may be flammable. The antifreeze used in civilian jeeps is water-borne and not flammable.
The Antifreeze used in military vehicles such as the wrecker, and every other military vehicle I have been licensed to drive, have used a 50/50 mixture of water and a ethylene glycol antifreeze. We use the same coolant in all wheeled military vehicles
The only vehicle I've seen that calls for flammable coolant/ antifreeze in my time wrenching is a 54 international t340 crawler that calls for kerosene or ethanol for conditions under 40 degrees... everything modern from over the road to military calls for ethylene glycol and water mix on later vehicles.
That's right I'm a window licker, I can't spell, my grammar sucks!!!!
