desertrunner
Just curious how far forward are you?So I’ve upsized to 37’s. My current set up is a 2.5 lift with stock arms in the rear. It works fine for the 35’s that are on it now but the rear wheels are no where near center of the wheel well. I know adjustable arms are the correct way to fix it but is there any reason I can’t cut/weld a section in to temporarily get me by until I can get adjustables? And if so does anyone happen to know approximately how long the rear arms need to be? Thanks
I am on 37s about 2.5" lift and stock rear lowers and my set up works just fine. The rear tire should not be centered in the wheel well at ride height, it should be center in the wheel well at full stuff and since the axle travels in an ark it is going to be forward of center at ride height. If you haven't trimmed your pinch seam already you are going to have to with 37s no matter what. If you center you axle at ride height then when you stuff the rear tires it will push back into the rear pinch seam. Either way you will have to trim, but the correct way to do it is have your axle centered at full stuff.
