kpig
Thought I would post my findings regarding aftermarket lockers for the Sport S with the max tow package wider axles.
The housings are the same as the Rubicon, but the centerline of the Rubicon locker is different from the open carrier of the max tow axle, making the axles different lengths. A call to Scott at ARB (thanks to Lisa Wade for the recommendation) confirmed that the ARB RD245 air locker will work on the max tow axles (front and rear).
The RD246 will work in either housing but would require Rubicon length 35 spline shafts. I guess if I ever get the urge to upgrade the shafts to 35 spline, maybe 60s would be more appropriate.
I'm happy to say that the lockers fit perfectly with the stock shafts and 5.13 gears. Now if only someone would make chromoly shafts for these unique length axles in the max tow housings.
Stay safe and healthy.
