Wethy
Well the time has come to swap the motor in my 14 Jk. It's lived a hard life that's for sure. Made it to 415,000 KM. Its down on compression and burns oil like you wouldnt believe. Original clutch, too.
That being said I've swapped motors before but usually on fwd cars. So i do have a couple questions.
Can i separate the transmission and leave it in place and pull the block out or is the recommended process to pull the block and transmission together?
Im also replacing the steering box at the aame time and the power steering pump as that doesnt come on the donor motor. Ia there limiter on the box or do i need to worry about rhe orientation on the output shaft?
Thanks in advance.
Thanks in advance.
