POLL : What Size Tire are You Running on Your Jeep?
What size tire are you running on your Jeep?
  • 30" or Less
    Votes: 3 0.6%
  • 31"
    Votes: 3 0.6%
  • 32" (255)
    Votes: 13 2.7%
  • 33" (265-285)
    Votes: 82 16.9%
  • 35" (305-315)
    Votes: 163 33.5%
  • 37"
    Votes: 171 35.2%
  • 38"
    Votes: 7 1.4%
  • 39"
    Votes: 4 0.8%
  • 40" or Bigger
    Votes: 40 8.2%
  • Total voters
    486
Faulka28
I run Toyo 37x12.5x 17 , with method 105’s
Usually air down to 15psi
Ps I need an air down tool since the one I purchased from a reputable Air locker company has faulty gauge and I can’t get them to respond to my request for warranty. I will be purchasing one soon unless I get lucky here :)
DZRTJP
Currently running the Hybrid Goodyear Wrangler UltraTerrain AT's in LT285/70R15. Haven't done a long, rough trail yet. But the short ones we've driven out to & back... these tires have worked So well, I haven't bothered to air down! Oh, and I run them on my stock Rubicon wheels... I like them :)
jesse3638
I run 37x12.50 R17's. I typically air down to 13-15 psi when off road and 10 on the rocks using my diy tire deflators.
Edit: Not sure why my tire size got cut off when I originally posted this.
curtiso504
Cindy and I are trying to get a better understanding of what size tire most of the members here on WAYALIFE are running. If you could please let us know by voting on our poll, we'd be most grateful. Of course, if you could also take a moment to let us know what you normally air them down to for the trail (if at all), you may just WIN a brand new EVO Tire Pressure Quick Air Down tool with digital gauge and carrying case!*
Thank you for your help :)
* A winner will be selected at random and announced on this thread.
Of course, you can always just buy one of these new EVO Tire Pressure Quick Air Down tools directly from Off Road Evolution. Simply click on the following link:
• Fast and accurate tire air deflation tool with instant pressure readings in .1 PSI increments.
• Digital display readings in 4 units: PSI, KPA, Bar, or Kg/cm^2 per your preference
• Easy to read digital illuminated display and rear body LED light allow for use at night, in dark places and gives a large clear display during the day.
• Digital gauge turns on and off with the press of a button and auto off in 2.5 minutes to conserve battery life.
• Instant pressure checks during deflation are easily made by the simple sliding up and down of the gauges outer valve collar.
• Extended stem for ease of use on all wheels including deep wheels and bead locks.
• Main valve, stem and hose are made from durable corrosion resistant brass and stainless steel materials.
• Hand held digital gauge unit is strategically isolated with a elastic rubber outer barrier for protection.
• Tool comes in a highly protective ready to go storage case for ease of storage and product protection.
12-15 psig
Brazilman
I currently have 33s. Once the rubber wears off I’ll lift my ‘19 Sahara and run 35s. I’d like 37s but not looking to regear and all that since I have the 2.0.
When on the trails I run between 15-18psi
