Jeep won't start after superchips programming interupted
Have you tried to pull the neg battery terminal for a few minutes and see what happens? Do you know at what point you turned off the jeep, was it while it was backing up your stock config or while flashing a new settting or tune? Can you get to reset to factory option if it has one?
I had reset my tune to stock. Then after starting it, the idle was too low. I turned off and attached the tuner to up the idle then it asked if this was the same car. I said yes, it reset tuner. Then when I tried to start, it wouldn't.
Yes, I did and nothing...
