juanbenae
Just got a set of Vision bead locks and am in the process of mounting my used 35-12.5-17's Cooper STT Pros and am looking for some input.  There is about 2/3 of the tread remaining and they are fairly chunked due to rock duty with little road use as it is not a daily driver. They were removed from a set of Method wheels that I had damaged a couple of the last couple years by cracking the bead portions off of.  I have read here and elsewhere the difficulties some have had balancing them, which I did not when they were new but have concerns with their current shape.  I have also read here specifically the distain for balancing beads but am looking for experiences/opinions in doing what I am attempting to do and my best approach.  The tire shop I work with has said they will give balancing them a try but suggested it may not be a reasonable expectation to get them right with the tire condition.
Another challenge will be that living in the sierras in a snow region where it gets cold this time of year the stiffness of the tires in a cold, stiff state. I do have a woodstove in the garage and plan on firing it to heat the tires some before installing & torquing the rings. Thoughts on this? I will not be putting them closer than 5-6 feet from the stove and let them heat for a few hours, cause the sun ain't gunna do it currently..... What temp would you suggest the rubber should be to accomplish this?
I am in no hurry as my winter snow tires are currently on the rig until spring when the forestry dept. gates swing back open. This is good in that I have time, but bad in that they will be mounted and attempted to be balanced before I can road test all 4 of them. I am reluctant to use balancing beads from jump, but may have to if spinning them is a nonstarter.
Input on directions I should head?
		 Since they’re 35s it may not be as bad as with the 37s.  Have them do a dynamic balance… that’s important, if they don’t you’ll not be happy.
