1941 Willy’s Slat Grill
piginajeep
The Original Smartass
Well, I was shopping the inter webs for parts for my other flat fender and found this not far from Eddie’s place in Nevada.
1941 Willys Slat grill, number 13,489 off the assembly line. These were built prior to Ford getting the contract. It’s really one of my Holy Grail jeeps I’ve always wanted.
It has not ran in years, but I bet I get it going this weekend. I’ll be updating the thread as I learn the history.
It’s titled in California and spent most of its life in SoCal, so maybe it’s from one of the bases.
Ford Engine (should not have)
Later model tub in 42 or so.
Frame vin matches the title. 113489
Combat Rims, also came after 42.
It came with a super clean bantam trailer. (Thanks Eddie and Cindy :) )
It’s definitely a Ford motor in a jeep !! That’s some bullshit.
I hooked a jump box up and it turned over. Going to check compression and buy a oil pressure gauge and see where it’s at,
I wonder which one will be on the road first ?
Started working on getting it fired up today, pulled the fuel tank, pump and lines. None of this shit is original. At some point I’ll get it close .
I ordered a carb rebuild kit, some brake parts. Started spraying PB blaster to get everything back moving.
With any luck I’ll at least get it fired up soon.
Well, it has oil pressure and enough to make the oil canister leak.
It also fired up with one shot of starting fluid, I grabbed some parts from my other flatty project. Unfortunately this carb won’t work.
Soon as I rebuild kit for this carb, it’ll be running 😍
