Rigid Dually JK fog light brackets $40
4x4Jesus
Rigid industries brackets to mount a set of duallys in the factory fog light location or mount in any aftermarket bumper that uses factory fog lights. $40 located in Mission Viejo,CaImageUploadedByWAYALIFE1384647775.380151.jpgImageUploadedByWAYALIFE1384647785.043014.jpgImageUploadedByWAYALIFE1384647793.042614.jpg
Can you use the factory wiring for that kind of light? If so I'm interested if you'll mail them
Did you do the spot light or flood light pattern?
I have spots in the bumper. That choice depends on the bumper you are using. The poison spyder bumper I have pretty much demands spots. With the brackets the lights are sunken into my bumper pretty far and I think the flood pattern would not work well. The light would probably be hitting the inside of the bumper. If the bumper u have allows the lights to sit flush then the flood would be nice. I made up for it with a 50" bar and some rigid floods on the windshield.
The rigid duallys come with their own harness that's really simple to wire or you can splice in to the factory wiring. I chose to use the harness so I could run them with my high beams. I was running the flood pattern lights
