DWiggles
So why are the okay for the d ring mounts?
The units for loads are all in pressure (force over distrubuted area) so the reason socket cap screws provide acceotable mounting for the d-ring mounts is because the relatively large contact area of the d ring mount to the bumper in comparison to the distance from the plate to the shackle. when you apply a load to the stinger (or example hang on it) you are now MUCH further from the *relitively small* contact area of the stinger mount to the bumper in comparison to the hoop of the stinger.
Edit: force over area, multiplied by distance is a direct multiplier, this is why it is ease to break bolts loose with longer wrenches, this is because you can use a longer wrench, and apply less force to the end of the wrench and through the simple "moment mechanics" you can apply a LOT more force on the stubborn bolt. This is the same concept described above ^^^
