BumblebeeZA
Ok so the topic has been mentioned many times before.
I went through most of them and did as best as possible as recommended.
I however still have a wobble when hitting a bump or "hole".
I never had the issue before the lift, I recently installed a 2' spacer lift, no shock extensions no relocation brackets... nothing except the spacers.
I re centered my steering after the lift and I still get a BAD wobble when hitting a bump etc at about 90 - 100km/h (55 - 60m/h)
I checked all my ball joints in the steering system, all 100%
No play in the trackbar.
Theres is literally no play anywhere in the system.
Could this be caster related or axle angle related?
Should I remove the spacers and save for a proper lift?
I also recently received 4 2nd hand 255/75R17 GY Wrangler AT tyres from a friend which I put on and balanced. 2 new, and 2 with about 4mm tread left, new at the back, used in the front.
Could it be my tires causing the wobble?
Normal cruising no issues or shimmy when driving at about 90 - 100km/h (55 - 60m/h)
