Thanks. Yea I've posted a few of the different things I've done. Mostly on this thread.
Switched out the tops today to get ready for Jeep Beach next week. Every year I think it takes less time to switch the tops out then it actually does.
I finally saved up enough coin for the EVO Tire Carrier, skins and three light. They're installing it on May 4th-8th. Pictures of course to follow
Installed my teraflex speed bumps in the rear (replaced the solid rubber block), and installed my EVO rear fascia and D-Ring kit.
Going to go back one weekend and trim down the frame for a flush look, and adjust my TF mudflaps a bit for better fitment on the fascia.
And had some fun out in the woods.
Installed a Maximus 3 stinger on the jeep last night. It's pretty sturdy, put all my weight on it and tried to wiggle it and it stayed solid :thumbup:
I got the EVO tire carrier and skins installed and I couldn't be more happy. A little more adjustment and it'll be golden.
With the new obnoxious reverse lights.
And a little bashed up. I need to powder coat it.
Finally got my new tires... not bad, slight rub on air dam (I think) at full lock. Have to investigate more this afternoon... only drove it for 30 min since I got her out of the tire shop...
Just installed the JK Rock Brawler this weekend. Ok... First of when people say reading is fundamental, I thought it was just one of those sayings. You know like "if your going to be dumb, your going to be strong."
Well this bumper, although worth the extra time I spent, was a pain in the ass. Just like with a lot of PSC items, there was a lot of put on and take off only to drill a hole and put back on again.
If you purchase this, please read the instructions. You have to notch out frame and once you install the main bumper you have to mark the bottom holes, remove the bumper and drill out the lower subframe. If you don't, then your nuts will fit in until they bottom out and break off. Only two broke but FML... Haha. Sorry for the rant.
Anyways next is the wench. Thankfully there is enough room to put your bolts in without having to remove the entire bumper. ImageUploadedByWAYALIFE1429132457.908380.jpgImageUploadedByWAYALIFE1429132483.876243.jpgImageUploadedByWAYALIFE1429132527.827043.jpg
