TwistedJK
So last night we decided to take the kids out to the Ocala National Forest to check out the night sky. Before it was dark we started driving down some of the trails that started to turn into some really soft sugar sand. I had the jeep in 4Hi and was keeping a constant throttle to push our way through. While going up a hill, the jeep started to big and the tranny shifted into a lower gear ( I now know I should've kept it in 1st or 2nd). At that point the jeep started beeping and a warning indicator stayed "hot oil." Once I was through the sand I turned off the jeep to let it cool down for about 15-20 minutes. My oil level was fine and my temp gauge stayed dead center. Luckily I had some cell service out in b.f.e. And after a quick google search found out it has to do with my tranny overheating. My '07 does not have a tranny cooler, which from what I read is a necessity. This is my first automatic jeep FYI. Apparently this is Chryslers way of letting us know our transmissions are overheating by giving us a warning light.
Anyway, I ordered a B&M transmission cooler from Amazon prime last night. Fortunately it will be here tomorrow, because we leave for Georgia Thursday. I'll also be changing out the transmission and transfer case fluid, and while I'm at it the diff fluid too, using Eddie's write ups :thumb:
Just thought I'd put this out there in case anyone else runs across this problem. If you guys would like, I'll try and do a quick write up of installing the transmission cooler.
