LasVegasJK New member Jun 19, 2015 #1 The first cut was the worst. After that, it had to be finished.
chester Member Jun 20, 2015 #2 Looks good. The first cut is always the hardest but once you do it there's no going back.
georgi.photo New member Jun 20, 2015 #3 Sweet. Did you use rivers or self tapping screws? I added some edge trimmer to clean up the look.
Black Beaver New member Jun 20, 2015 #4 That looks good. I'm thinking on doing the same. Did you buy end caps or just use some of the stock plastic from the parts you cut?
LasVegasJK New member Jun 20, 2015 #6 georgi.photo said: Sweet. Did you use rivers or self tapping screws? I added some edge trimmer to clean up the look. Click to expand... I used self tappers. Painted them flat black.
LasVegasJK New member Jun 20, 2015 #7 Black Beaver said: That looks good. I'm thinking on doing the same. Did you buy end caps or just use some of the stock plastic from the parts you cut? Click to expand... I just used the end piece of the bumper. I made sure to cut the end piece off I was going to reuse FIRST. then I made second cut closer to center.
