Someone on here did that, it takes a decent ammount of trimming to clear them, but it can be done. Why not just get the evo leveling kit if you want to run 37s on the street?
I did that! Trim your fenders- flat fender mod, trim your front and rear pinch seams about 1.5"-2", install 2" bump stop extensions in the rear, rear out steering stops about 1/4", stubby your front bumper and trim the rear bumper or remove all together. Probably could have used a 1" bump stop extension in the Front, but where it rubbed the fender wasn't going to cause any damage. My 37s are on atx slabs, if they weren't, I believe a little more work would have been needed.
Doable: yes!
Recommended: no!
But this is just temporary, I need to sell my current wheels and tires so I'm going to throw the new ones on for a month or so just for street driving. Would that work?
You are going to have to do all the trimming just to get them to fit, no way around it. Any bump you hit without the rear bump stop extensions is going to cause the rear tires to rub into the top metal pinch seem cutting up your new tires. Like I said mine are on ATX slabs which have 3.5" backspace. If you get a wheel with less you will probably have to trim more of the front pinch seem and put a larger spacer in the steer stop. I ran that way from 6/21 till 9/7, then I installed my lift.
I have a cheap 3"; lift kit ...springs and stuff sitting in the garage, maybe just toss that on really quick until I get my evo full lift kit?
You would be better off doing that then just running stock.
C gussets! I installed C gussets before I put the 37's on those are highly recommended, definitely do c gussets
