Oil change
I swear i searched but couldnt find anything!
We have almost 2500 miles on the JKU and was wondering if i had to wait till 5k to change the oil, or do it sooner? The reason I ask is that someone told me over the weekend you were supposed to do the first one pretty early.
Thanks guys.
Thanks guys.
Read your manual so you understand the definition of "severe duty" intervals which is most everybody. I do mine every 3k to accommodate my ocd. 5k is fine.
Thanks guys.
You do know your Jeep has an indicator that tells you when to change the oil.
I go by indicator or a little longer... I have 113,000 on it. I do not understand people that change every 3,000 this day and age. It is a waste of time and money among other things.
Amen to that. I go at least 5k between changes, but I do use Royal Purple full synthetic
Sent from my SAMSUNG-SGH-I747 using WAYALIFE mobile app
I believe the manual says every 8k for my 2012. I do mine every 4k along with all my routine maintenance. Tire rotation, lift inspection/torque, grease drive shafts,
Sent from my 831C using WAYALIFE mobile app
I go by the indicator. Usually about every 7500 is where I end up. If I remember correctly the owners manual says not to exceed 10000. I did the first one at 1000 miles just to get out anything that may have gotten in there from the initial break in miles.
I will echo jesse as I change my conventional oil every 4,000 miles or so. This is one subject where opinions will vary!
Absolutely. Even occasional off-road use, and city driving is very hard on your engine. I shoot for 3k knowing that I'm usually too busy, so I know it's done by 4K. I Also run full synthetic in all my modern engines, just run conventional in my 77.
Here is a little snippet I found on the subject:
Matt Snider, project engineer in GM’s Fuels and Lubricants Group, has an answer:
“Vehicles are so sophisticated that oil is one of the last things that customers can have a direct influence over. There’s maybe some feeling that they’re taking care of their vehicle if they change their oil more often.”
Now, many people also make the argument, that it’s better to be safe than sorry, right? But that’s a nonsensical argument when the leading experts are all saying such frequent oil changes are simply not needed. There is no danger of being sorry. Your engine will be fine. But there is one real danger. The danger of pollution.
GM’s Matt Snider has said:
“If customers always just stayed with the 3,000-mile recommendation, they would be throwing away good oil.”
Product education specialist for Toyota, Chris Risdon, agreed. Advances in oil technology means that you can change oils much less frequently and protect the environment at the same time.
“If you’re doing it [changing oil] half as much, that’s 5 quarts of oil times 1.7 million vehicles a year — that’s a tremendous amount of waste oil that’s not being circulated into the environment.”
Waste oil is a serious problem that’s exacerbated by too-frequent oil changes. California Integrated Waste Management Board has campaigned against the 3,000-mile dictate for a while. The agency has reported that 153.5 million gallons of used oil is being generated in California every year, but only 59 percent of it is ever recycled. That’s a considerable amount of potential pollution dumped into the environment.
I've sent off several oil samples to Blackstone labs for analysis and have come to my current OCI's.
So what happens to the other 41 percent of used motor oil? Where/how is it "disposed of? I have a hard time believing it's just "dumped" somewhere. Seriously, if you or anyone else really knows, please tell us.
I'm from Louisiana so I can almost guarantee it's dumped in someone's back yard here.
I change my oil on my 2015 jku 4000-4500 k I use synthetic valvoline. It's getting pretty dark by then. I'm sure it's fine to go further, the thing that scares me for than oil life Is the sketchy oil filter housing....seems cheap and easy to break.
I did mine 500 miles into first break in... then every 5k with my free ones till just recently I used my last one. I'll start doing it myself and using Napa Platinum filters which are the best.. and Mobil 1. I'll attach a link to the best oil blog you can imagine the owner has produced so much information and debunked so many hypes... I use Mobil 1 synthetic in my LS7 race motor and its pulled after each season to be checked and no hard wear on it at all. yes there is a few better oils out there but when you use 12 quarts in your dry sump set up and change it after each race the more expensive stuff takes a toll on your wallet. and Corvette Racing uses the same oil and components I use in my engine and they have very little in the engine failure department.
https://540ratblog.wordpress.com
Really, thought you would remember that its supposed to be applied to your frame to keep it from rusting out?! :grayno: The rest is used to keep your attenuator reservoir topped off.
My 3.8 burns about a qt every 1k miles so I change my oil every 4kish miles with a 5 tire rotation.
I'm guessing they are comparing new oil sales to the amount brig recorded by the recyclers so there would be a lot of losses from leaking engines, blow by and transfer losses between containers, tanks etc. not too mention traffic crashes and guys dumping oil.
