WJCO
Meme King
You definitely got water in there. Check axle seals and pinion seal for leakage too. Water can get in there as well.
AlStew
Does your locker still function properly?
Lol...locker worked great 2 weeks. Just bad maintenance by me. Not changing the fluid in a long time and being lazy when I lifted my jeep, I left the breather hanging down.... thanks for looking out guys!
dchew
Rotated the tires and fixed two of my Hutchinsons with slow leaks that have been annoying me for months. Put it off long enough. Also replaced some grease fittings that had frozen shut.
JeepJeep75
ImageUploadedByWAYALIFE1483328025.577019.jpg Installed my JW fog lights. ImageUploadedByWAYALIFE1483328088.412019.jpg I had to remove the grill and un-mount my winch ImageUploadedByWAYALIFE1483328190.326234.jpg added in the JW connector into the factory wire loom ImageUploadedByWAYALIFE1483328242.966984.jpg Even went as far as to drill a hole in the bottom of the bumper to access the adjustment screw for the fog light. Crazy, I know....
