I would trust the axles on a hot wheels car before I would trust a teraflex drivetrain part. Go prorock.Which is better tera44 hd with 3.25 dia and .5 thickness or the pro rock 44 with 3" and .5 thickness. I know thicker dia helps prevent bending and thickness prevents denting. Which has better knuckles?
You can keep your rear 44, and just get a new front if you are staying <= 37s
Sent from my SAMSUNG-SM-N920A using Tapatalk
I believe the ud44 is no stronger than a rubi44
Thanks for that mental imageIf you met a couple of hot blondes at the bar one night and one of them turned out to have a dick, does it really matter how pretty she is?
After seeing pictures of Teraflex arms break, tire carriers break, and control arms break, I would completely remove them from the equation regardless of the specs they claim. If you met a couple of hot blondes at the bar one night and one of them turned out to have a dick, does it really matter how pretty she is?
