chitown35
LOSER
The stock stuff seems pretty firm, and I assume it'll do its job? But the stuff that goes with the cage I just added seems cheap and like not much more than a pool noodle. Anybody else have the same thoughts?
I saw this stuff online, which is described like it's exactly what should be used: https://www.pegasusautoracing.com/productselection.asp?Product=2390 right?
"This high-density padding should be used any place on a roll bar or roll cage where the occupants may come in contact with the tubing. It is very dense to minimize bottoming out in hard impacts, but it is pliable enough to reduce the risk of broken bones and severe bruising. This padding is much harder than the foam-rubber "comfort" padding typically used on Jeep rollcages, but it is softer than SFI-rated padding."
But who knows, maybe the stuff I already have is the same as that.
Anybody care to share what they've used?
