aermid
Was noticing a new click clack under the Jeep today so checked it out when I got home. Needed to tighten down my passenger rear sway bar, nbd. Decided to do a more thorough check of other bolts and noticed this:
My lift's rear trackbar relocation bracket (Rock Krawler 2.5 Flex) eating into the protection sleeve (not sure what the official name of that thing is) of my drive side ebrake cable. Luckily it looks like the cable is fine. I drive a manual so I use the ebrake as well as leaving it in gear when parked.
I ended up surrounding the bolt with some extra door trim padding I had laying around and gorilla tapped the crap out of everything so the metal bolt couldn't dig into it any more and covered up the damaged sleeve, but need to think of a more permanent solution.
--Erin
--Erin
