Annoying rattling exhaust noise
MSJKU11
So I finally found my annoying little metal noise. Always came up after I drove for about 15-20 mins. My exhaust seems to be vibrating on that bracket. I tightened everything down there but seems to still create a noise. I originally thought just to place some steel wool between the pipe and the metal but is that flammable? Any other suggestions that I could use to soften the noise? zcamera-20171004_190846.jpg
BFH to either part. You could add a .250 washer as a spacer.
check the rubber exhaust isolator on the frame side hanger of the cat and pipe section
mine was doing the same thing and I noticed if I pushed up on the isolator it would stop.
I used stainless zip tie I had and wrapped it around the ends of the exhaust hangers to pull them closer together.
new isolators are only $3-$5...I need to order new ones.
