WJCO's Build Thread, 1999 WJ
Worked on the high lift mount for the carrier today. I had enough steel sitting around that I just decided to build one. I just kept it simple. I basically just need to weld a bracket at the top to secure it and drill a couple of holes and it's done. Not sure when I'll get to that.
Finished the jack mount today. Made a support bracket and welded it on.
Had the perfect piece of scrap to make a clearance spacer that the bolt could still go through.
Bolted up with a wing nut. I need a shorter bolt, but that's all I had at the time. There's one more bolt on the bottom pedastal that I forgot to take a picture of, it also has a wing nut.
I didn't anticipate this, but lucked out. To open the hatch, I have to push the carrier out quite a ways. Then after the hatch is closed, the carrier/jack come to rest here. Just below the paint. Close one.
And here's the finished product. Feels good to be a real Jeeper again.
Lookin good! Now all you need is a gay switch panel that doesn't line up and includes an in car winch control no one ever uses and you'll be set! :thumb:
Thanks.
:cheesy: So true.
Looks good!... what about chopping an Inch or so off the highlift for extra clearance? Do you need the top hole?
I need all the holes :D
I really did think about cutting off a few inches.
Looks good! Bonus points for setting it up to use the Jack to hold up the gate when the struts wear out. 😂
Didn't think about that! So true, I may just leave it as is.
Looking good...and I can understand why you worked on it today instead of watching the Broncos...at least my team has a qb...
And I noticed that you are totally ignoring my Broncos taunt...I can only assume you are awaiting the outcome of the Sunday night game...GO RAIDERS!....
I'm having a little trouble understanding your posts with all that badass color you inserted.
