Disciple Off Road
Correct, 2.5” lift or less does not need spacers with factory wheelsI'm pretty sure that Trail Bud or anyone else running this setup is NOT running wheel spacers.
Lol... these were $500 and I can put my OEMs back on in the winter. Wide tires suck in the Denver icy, slushy roads.Should have done 35’s….
I had to say it only because you were so undecidedLol... these were $500 and I can put my OEMs back on in the winter. Wide tires suck in the Denver icy, slushy roads.
How far is your shop from Phoenix? I may need to go there after the Nascar weekend to re-gear.Correct, 2.5” lift or less does not need spacers with factory wheels![]()
Should be about 8 hours. Trust me, it'd be worth the drive.How far is your shop from Phoenix? I may need to go there after the Nascar weekend to re-gear.
Yes... the internet influencers and local shop said conflicting informationI had to say it only because you were so undecided![]()
It should auto register after you drive for a bit. THAT SAID, there was change in the type of TPMS used somewhere in the middle of 2019 and depending on what Jeep your wheels came from, they may not ever register on your Jeep.Do TPMS auto register? Or do I need to goto a tire shop to get them programed?
Mine reset w/o any type of programming.Do TPMS auto register? Or do I need to goto a tire shop to get them programed?
mine never reset but a quick trip to Discount fixed it.It should auto register after you drive for a bit. THAT SAID, there was change in the type of TPMS used somewhere in the middle of 2019 and depending on what Jeep your wheels came from, they may not ever register on your Jeep.
Yep go 37's all day. Put 35's on my JTR and now getting ready for 37's. Only saving grace is the 35's can go on my wife's JL. Like has already been said a few times I regret not buying the 37's out of the gate.Man, should I just bite the bullet and skip 35s and get 37s? New wheels plus 37. I have 2.5 inch full lift. Steelie wheels.
How bad would it be with the stock gearing for the summer with 37s? Not daily driven.
2018 JLU Rubicon is what they came off. After a quick 15 miles, they didn't register.It should auto register after you drive for a bit. THAT SAID, there was change in the type of TPMS used somewhere in the middle of 2019 and depending on what Jeep your wheels came from, they may not ever register on your Jeep.
5 inches is 127mm 1in = 25.4mmIf 4.53 back spacing is what you're looking for, yeah, that should do the trick.
Also, I can't remember for sure but I don't think 5x5 bolt pattern (what you need) is the same as 5-127.
EDIT : I think they can be used interchangeably
See EDIT5 inches is 127mm 1in = 25.4mm
They have 3.5" version, but they are more expensive. I care more about function than look. Which would rub less? Drive better?
Great shot and good tire. Yes, they are now owned by Goodyear just like Cooper who originally made Mickey Thompson and so they are American tires. Only heartache I have with any of those companies is that the Goodyear went all woke, pro BLM and defund the police when it was trendy a few years back. Hopefully things have changed.Those worn BFGs are gone and replaced with MT Baja Boss A/Ts. The worn BFGs had almost no traction.
And best part, the Mickey Thompsons are made in the USA!View attachment 428660
