Main Seal Leaking?
While under the Jeep taking off the rear driveshaft for the third time, I noticed this… am I fooked? 😢
At first glance I was gonna say oil cooler from up top but, zoomed in I can see it’s starting there… 😬 That’s a bummer but I hope you can sort it out quick.
pull the rubber plugs, have a paper towel ready to catch what drains out and see what color it is and how much.
it's very much an annoyance on these newer sealed transmissions, no dip stick to easily check the level but you can check it from the fill plug.
edit: the transmission pan is an easy job to replace filter and seal. there is a specific refill process to get the level correct
Thanks, Joel, I can try that tomorrow when I try Eddie’s sniff test. 👍🏻
We just did it on my dads gladiator, “lifetime” fluid looked like total garbage on the way out but it’s normal again lol.
Yea full drop and filter change, they say you don’t need to do it, but my dad being “old school” mechanic, ect, it wasn’t leaking but had a random hard time shifting at high rpm, back to flawless and the oil looked like dog shit. But to Joel’s point there is a very specific fill procedure.
Nice. Maybe I’ll wait to do all of this until after the NYKO run.
that's the same reason I did mine, the shifting changed.
It was far from lifetime looking, looked more like it had several lifetime deaths
I’m at 88k and change and given the amount of wheeling we do, makes sense that it’s bad I guess.
changed mine at 81258, I captured as much as possible to compare what went in but I think it came low from the factory, I put more in than came out.
edit: I did install a larger capacity transmission pan but that should have only added one quart, put more than that back in.
It does not look fresh to me so I would clean everything up with some degreaser and have a few test drives to try and locate fresh fluid if it appears.
Indeed smell it as Eddie mentioned. Check around transmutation pan gasket and oil filter housing. I would start there.
Pull the rubber plugs and if nothing comes out I would do as Andy said and clean everything real good then go on a test drive or two. See if you can locate where it’s coming from better. Doesn’t look like a rear main to me from the pics. Looks like it’s coming from higher.
I would recommend a trans service tho. I’m about to do one at 42k miles on my jeep.
