Andy5160
Get it over with !!!Getting closer to going in
lol synergy knuckles just showed up yesterdayGet it over with !!!
looks too pretty to install, encase it in glass and hang it on your wallGetting closer to going in
Heck yeah dude congrats!!UD44 is finally in! View attachment 436647View attachment 436648
View attachment 436650View attachment 436649
Didn’t get any other pics of it bolted up but I will take some later.
Well done!!! Did you figure out lockers wiring?UD44 is finally in! View attachment 436647View attachment 436648
Yup! Front was easy as it already had a pigtail so just needed to run power and ground up to the factory aux switch wiring. Same with the rear locker, just used the wiring diagram and used pins 1 and 4 and ran them up to the factory aux switch as well.Well done!!! Did you figure out lockers wiring?
SimpleYup! Front was easy as it already had a pigtail so just needed to run power and ground up to the factory aux switch wiring. Same with the rear locker, just used the wiring diagram and used pins 1 and 4 and ran them up to the factory aux switch as well.
Nice! I really liked this mod.Fender chop timeView attachment 438657
Shits taking a lot longer than I thought it would lol. I like it as well thoNice! I really liked this mod.
Looks great!Lights are in, 1/2” spacer is in, new OEM drag link, diff fluid changed in the UD44, lockers wired to factory aux switches, and compressor switched moved to under the hood
View attachment 438669View attachment 438670
Now to align
Thanks Mike!Looks great!![]()
