While on Cliff Hanger last week I munched one side of my front antirocks on the first major obstacle coming up out of the creek. Wrapped it around the tie rod from over centering it. Good to see they sell the components so an easy fix. Parts are on the way.
Bummer. Looks like you are/were running links that are too short.
Probably true, I added 3.5 inch RK springs right before the trip, up from 2.5. Modded the RK arms but didn't touch the links. Lesson learned.
How many guys use limit straps to avoid over travel?
The ONLY reason to run limiting straps is if you have so much droop that your drive shafts bind at a full droop. Other than that, your shocks are your limiting straps.
