Nice, that’s awesome! That sube was munched!I made this slider deal a while back that helps keep the frame solid on impact.
Bummer. Looks like you are/were running links that are too short.While on Cliff Hanger last week I munched one side of my front antirocks on the first major obstacle coming up out of the creek. Wrapped it around the tie rod from over centering it. Good to see they sell the components so an easy fix. Parts are on the way.
Probably true, I added 3.5 inch RK springs right before the trip, up from 2.5. Modded the RK arms but didn't touch the links. Lesson learned.Bummer. Looks like you are/were running links that are too short.
The ONLY reason to run limiting straps is if you have so much droop that your drive shafts bind at a full droop. Other than that, your shocks are your limiting straps.Probably true, I added 3.5 inch RK springs right before the trip, up from 2.5. Modded the RK arms but didn't touch the links. Lesson learned.
How many guys use limit straps to avoid over travel?
You need longer links not limiting straps.Probably true, I added 3.5 inch RK springs right before the trip, up from 2.5. Modded the RK arms but didn't touch the links. Lesson learned.
Thanks, I've run the old setup for 5 years with no issues. amazing what another inch will do. ;-)The ONLY reason to run limiting straps is if you have so much droop that your drive shafts bind at a full droop. Other than that, your shocks are your limiting straps.
