Page 28 of 29 FirstFirst ... 1826272829 LastLast
Results 271 to 280 of 281
Thread: ATTENTION: Know Your Jeep JK Wrangler Coolants and Save Your Engine!
  1. #271
    Fresh Catch
    Join Date
    Oct 2019
    Location
    Great Falls, MT
    Posts
    2
    New (to me) ‘13 JK, needs coolant
    I did some pretty extensive reading on this thread, and in other places around the internet. As with most information gathering, the more you learn about a subject, the less sure you become. My question is this:
    I bought my JK not too long ago and the coolant is low. When I look down into the overflow reservoir it looks orange just like the OP said.
    HOWEVER, the CarFax report said that the radiator had been replaced (by a Chevy dealership), so I suspect they may have used regular orange coolant. Furthermore, the OP statement below leads me to think that non-Mopar, OAT coolant will be Orange:
    “A little background on the color so that the next part makes sense to you guys....As we know, FIAT is with Chrysler now. Fiat has been using orange colored OAT for years. When Chrysler switched to OAT, they didn't want dealers/people getting confused, so to differentiate the new OAT coolant with the chrysler original orange HOAT, they added a purple dye. As a result, due to a weird light refraction, the purple OAT looks weird (even orange) when looked at certain angles. You can even pop open your radiator cap on your 14 and the coolant looks so orange you'd bet me your jeep that it's orange....but it isn't.”
    Moving on, if I buy Peak Antifreeze, that’s rated for Chrysler 2013+, says it’s OAT, but is orange in color, would that be wrong? (https://peakauto.com/products/antifr...d-life-orange/)
    And lastly, since it is not the factory radiator/coolant, is there an easier way to check or even “dip” the reservoir?
  2. #272
    Fresh Catch
    Join Date
    Oct 2019
    Location
    Great Falls, MT
    Posts
    2
    Quote Originally Posted by Waxmell7 View Post
    Well I figured this part out. But anyone have input on whether it’s OAT or HOAT? Base on my readings I’m assuming OAT.
    Attached Images Attached Images
  3. #273
    Knows a Thing or Two Spazbyt's Avatar
    Join Date
    Oct 2015
    Location
    St.Peters, MO
    Posts
    583
    Honestly I just went through this yesterday. I wasn't going to just hope that my purplish orange stuff was OAT so I just flushed the hole system. Now I know exactly what I have. A few months ago I had top it off with green "universal" after doing all the research. Then I found some sludge in the bottom of my overflow so I freaked my self out and flushed it all. Problem solved.
    Sent from my SM-G960U using WAYALIFE mobile app
    I've never done it but I'm sure i'll be good at it
  4. #274
    Fresh Catch
    Join Date
    Apr 2017
    Location
    Gilbert, AZ
    Posts
    7
    Confusion over Part Number
    You state the part number is: 68163849AA
    However, the Chyrsler TSB you reference states the part number as: MOPAR P/N 68163848AA
    Now I'm more confused than before.
  5. #275
    Nothing but a Thing MericaMade's Avatar
    Join Date
    Nov 2017
    Location
    SoCaL
    Posts
    2,280
    Quote Originally Posted by JKURAZ View Post
    I think 48 is concentrate and 49 is the 50/50 mix.
  6. #276
    Nothing but a Thing Overland_stormtrooper's Avatar
    Join Date
    Aug 2016
    Location
    Tyler Texas
    Posts
    1,501
    Correct
    Quote Originally Posted by MericaMade View Post
  7. #277
    Fresh Catch
    Join Date
    May 2020
    Location
    Springfield, MO
    Posts
    1
    So glad I found this thread! After owning TJs, I recently purchased my first JK, a 2013 Wrangler Sport with 75k miles. Just last night I changed all the fluids, because I have no idea if the two previous owners followed any of the recommended service intervals, and I just wanted a fresh starting point going forward. So I changed brake, power steering, oil, manual transmission, transfer case, and diff fluids.
    The ONLY thing I didn't change was the coolant, because I honestly just didn't feel like messing with flushing it. I'm so glad I didn't! I can tell you right now 100% I would've grabbed a bottle of the orange stuff at O'Reilly and screwed up my coolant system.
    I just this morning decided to research the flushing process and stumbled on these HOAT vs OAT threads. Now I know to make sure which I have first (should be OAT, since I have a 2013), and I also know my fluid is still theoretically good for another 75k miles, so I just need to test it occasionally.
    Thank you so much to the OP for this detailed information!!
  8. #278
    Fresh Catch DarkSpeed's Avatar
    Join Date
    Jan 2020
    Location
    Spokane, Wa
    Posts
    3
    Quote Originally Posted by NFRs2000NYC View Post
    I hope this post helps some members along the way!
    Dave
    Awesome work. Thank you!
  9. #279
    Fresh Catch
    Join Date
    Dec 2020
    Location
    GA
    Posts
    1
    I have a 2013 jku Sahara the build date is November 2012. Would it be using hoat or oat?
  10. #280
    Old Timer sipafz's Avatar
    Join Date
    Mar 2015
    Location
    Saukville, Wisconsin
    Posts
    2,912
    Quote Originally Posted by nsmac84 View Post
    Look in your owners manual.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
