Results 1 to 7 of 7
Thread: Rear drive shaft advice
  1. #1
    Hooked Sugarbear's Avatar
    Join Date
    Dec 2013
    Location
    Macungie Pennsylvania
    Posts
    211
    So I have a 2014 2 door I just got a zone 3inch kit and a coast 1310 front shaft my question is is it necessary to also get a new rear shaft or can I go a while without it come summer time I'll be on the trail at least once a month if not more so will I be ok with a stock shaft with a 3 inch kit ??
  2. #2
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,698
    You'll be fine for a while, maybe as long as a year or so or up to 30,000... less if you do a lot of wheeling. I would just save up and run it until you start to see grease spitting out of the CV boot or can afford to replace it. You will need adjustable rear upper arms as well to set your pinion angle.
  3. #3
    Join Date
    Dec 2013
    Location
    Posts
    211
    Will I need the arms right away ?? I didn't think the pinion angle would be that much to matter a lot I know it changes a little but how drastic? I have the money for one or the other at the moment so what's your recommendation
  4. #4
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,698
    Quote Originally Posted by Sugarbear View Post
    It is ESSENTIAL to set your rear pinion angle when installing a u-joint style double cardan drive shaft. This angle will be considerable and the only way you can do this is with a set of adjustable rear upper control arms. Failure to do this will result in significant vibrations.
  5. #5
    Join Date
    Dec 2013
    Location
    Posts
    211
    Forgive me for my lack of understanding here Eddie so I take what your sayin as I'll be ok on stock rear shaft and stock arms but when I upgrade the shaft I need to also get the arms
    Correct? Or incorrect?
  6. #6
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,698
    Correct. The factory rear drive shaft uses rzeppa joints on both ends and will operate vibration free even at a steep angle. The problem with them is that the angle it will sit in will be steep enough to cause the CV boots to be in a constant state of pinch. This will cause them to fail prematurely and once they have been compromised, there will be nothing to hold the grease inside. With that, total failure of the bearing inside is imminent. U-joint style shafts with a double cardan NEEDS to be set in line with the pinion. Are you following me?
  7. #7
    Join Date
    Dec 2013
    Location
    Posts
    211
    Yes sir I gotcha clear now. thanks once again for enlightening me with your superior knowledge and saving me tons of money from unneeded mistakes lol
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
