Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: 4" Double D JK Bolt On Long Arm
  1. #31
    Addict StrizzyChris's Avatar
    Join Date
    Apr 2012
    Location
    SouthWest OH
    Posts
    5,164
    Rubicat has the high clearance long arm system that's been modified to work with the EVO bolt on coilovers...not the DoubleD system. Both long arm systems work with a 2014 but require exhaust modification (as do every manufacturers long arms
    2013 Dune JKU Rubicon <-- Build Thread
    37" Nitto Trail Grapplers on 17" ATX Slabs, EVO BO Coilovers Front and Rear, GenRight Rear Tire Carrier, RK Front lower Control Arms, Adams 1310 Front DS, LOD Sliders, DynoMax Comp Exhaust, EVO ProTek Skids, Fender Trim, EVO 1/4 Pounder and stinger, Warn 9.5ti, EVO C-Gussets, AEV Procal, Trektop NX
    ***Buy Jeep parts Made in the U.S.A.!!!***
  2. #32
    Moderator Trail JK's Avatar
    Join Date
    Feb 2012
    Location
    Reche Canyon
    Posts
    3,052
    Quote Originally Posted by StrizzyChris View Post
    Cool, moved exhaust today. Thanks!
  3. #33
    Been Around the Block iRonin's Avatar
    Join Date
    Jan 2014
    Location
    Austin, TX
    Posts
    467
    Not to resurrect this thread, but I'm not sure my question warrants a new thread and half of my dilemma deals with the DD long arm so, here goes;
    I'm about to pull the trigger on one of these two packages:
    EVO MANUFACTURING JK ENFORCER PRO STAGE 1: http://www.northridge4x4.com/evo-man...ge-1-evo-201-1
    EVO MANUFACTURING JK 4 INCH DOUBLED BOLT ON LONG ARM KIT: http://www.northridge4x4.com/evo-man...rm-kit-evo1084
    My application is a '14 JKU that I primarily want for serious rock crawling, with the secondary desire to (eventually) have it do the faster stuff too (i.e. upgrade to DTD/evolever).
    I would be running either package with a 37" tire.
    By the time I add in the shocks that don't come with the LA, the price diff between the two is similar enough. So what I'm more concerned about is:
    1. How much of either kit will survive the transition to DTD in the future
    2. Which kit will better suit me even if DTD never comes to fruition and I'm happy just crawling.
    Assertions I am looking to confirm or understand better based on my research:
    1. LA vs. SA aside, limiting factor is the shocks as far as travel. Either kit is engineered for a potential 14", but Enforcer Pro advertises 12" of travel on the Kings. If I go with the LA kit and pair it up with some Fox 2.0 shocks, I can get them in 11" travel, so between the two configurations (12" on SA/Enforcer Pro or 11" on LA/DD) there would only be 1" of travel difference, is this correct?
    2. The coilovers from the enforcer pro would....not(?) survive the transition to a DTD/EvoLever?
    3. Do at least the front coilover shock mounts / bracketry survive moving to DTD? EvoLever is obviously completely diff.
    Hopefully you see what I'm getting at- my gut is telling me that the LA kit is the better initial investment if the for-sure plan is to go DTD in the future since it seems like all the control arms would be reused, and the loss of the springs and cheaper shocks won't be as severe as ditching the kings. On the other hand, the enforcer pro seems like the better all-around investment that would still do decently on the fast stuff if I decide not to upgrade to DTD in the furture...
    Am I looking at this right? Over complicating it?
    - iRonin aka "Thanos"
    | Build Thread | Instagram | Youtube |
  4. #34
    Join Date
    Mar 2014
    Location
    Dana Point
    Posts
    1,511
    Quote Originally Posted by iRonin View Post
    Nothing really survives - except control arms - Maybe a better way to look at this is IF DTD is what you want end state - Then "what do I need to get there" then do the things that work with you current setup. There is no mention of axles in your post just DTD - new axles will require all sorts of new things and will allow you to enjoy your DTD.
    The bolt on kit with the long arms will be a nice capable setup that will do you well if you never do another thing.
  5. #35
    Join Date
    Jan 2014
    Location
    Austin, TX
    Posts
    467
    Quote Originally Posted by branman View Post
    Thanks branman, I did omit the other components on purpose for brevity but along with either kit I already have a pr44 earmarked for the front, and have already upgraded my other steering components in anticipation (track bar, tie rod) .
    I was indeed leaning on the LA kit as I feared not much from the pro would make it, this helps solidify the decision.
    Edit: Turns out that with the wayalife discount, it's actually $20 cheaper for me to get the enforcer pro since the discount doesn't apply to the separate shocks with the LA kit. So I suppose at that point it's down to sacrificing a smoother ride on pavement to gain 1" additional travel and a cleaner coilover system with a much nicer set of kings
    Last edited by iRonin; 01-22-2015 at 08:34 PM. Reason: Price diff making it interesting.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
