Close
Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
  1. #61
    Hooked r2fasani's Avatar
    Join Date
    Feb 2014
    Location
    Ripon, CA
    Posts
    158
    Outside of it never happening in the first place, this is the best outcome in this situation. I commend Eddie for his "water under the bridge" attitude. Not that you need it from me... I just respect it is all.
  2. #62
    Join Date
    Jan 2013
    Location
    Denver CO
    Posts
    136
    Quote Originally Posted by LoPo View Post
    Nothing posted on the internet ever dies.
    http://webcache.googleusercontent.co...&ct=clnk&gl=us
    Ugh.... So what you're saying is that video with me and Megan Fox is still out there?
  3. #63
    Old Timer Rccrwlr's Avatar
    Join Date
    Mar 2013
    Location
    Here
    Posts
    2,674
    Lingering write ups on the site still. They did give credit but I thought it was all taken down.
    http://www.jeep4x4center.com/blog/?p=986
    Jeep error codes
    Thanks to Jeep and their progression of onboard technology, just about every single part on your new Jeep JK Wrangler is wired up to a computer (BCM, ABS, ECU). And, if anything goes wrong, your Jeep’s computer will make a note of it and/or even let you know about it by illuminating a Malfunction Indicator Light (MIL for short or “check engine light”) icon on your dash. Unfortunately, the MIL or other icons won’t tell you a whole lot other than the fact that your Jeep is having some kind of a problem and unless you take your Jeep into the dealership or have your own OBDII reader handy, you’re pretty much out of luck, right? Wrong. Luck would have it, the Jeep JK Wrangler’s come with an onboard Diagnostic Trouble Code (DTC) reader built right into the dash. You can access the codes by following the 3 simple steps. Once you have the DTC code(s) in hand, check it/them against the list below and you will be able to find out exactly what problems your Jeep is having.
    To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
    If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes as shown in the pic to the left. If your Jeep JK Wrangler has any logged in any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s) and check it/them against the list below to find out what they mean.
    If your Jeep JK Wrangler has not logged in any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
    How to Read a DTC
    A DTC or Diagnostic Trouble Code is made up of 5 digits the first of which is one of the following letters:
    B – Body
    C – Chasis
    P – Power Train
    U – Network
    The 2nd digit indicates:
    0 – SAE
    1 – MFG
    The 3rd digit indicates:
    1 – Fuel & Air Metering
    2 – Fuel & Air Metering
    (Injector Circuit)
    3 – Injection Systems or Misfire
    4 – Auxillary Emissions Control
    5 – Vehicle Speed Control
    & Idle Control System
    6 – Computer Output Circuit
    7 – Transmission
    8 – Transmission
    The last 2 digits indicate:
    Fault (00-99)
    Special Thanks To Project-JK
    Looks like I'm locked out. Why?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
