For those of you looking for a new front axle that will last longer than the life your Jeep JK Wrangler and well beyond the next one as well, this is the axle for you - the Dynatrac ProRock XD60!! Released at the 2014 SEMA Show, it features the patented ProRock design which provides the BEST ground clearance in the industry, allows for a 10.1" ring gear which provides 16% more strength over the already strong standard ProRock 60, offers an optional larger carrier and pinion bearings for more strength, has a center section that is more ridged and lighter, includes a proprietary internal Dual Sump High Volume (DSHV) lubrication system and comes with an all new differential cover that has deeply recessed bolt holes to protect the bolt heads. When coupled with the all new and massive Dynatrac 1550 HD wheel ends that allow for 1550 steering joints and 3-3/4" axle tubes, you really will have the best that money can buy.
Check out the massive but light weight cast aluminum axle end...
