iRonin
Project Thanos Build
Whelp, I've been on here for a while now, and I've always meant to get a build thread going, but I think I was waiting for a significant mod before doing so, just so the first bunch of updates weren't all minor.
Most of the work you'll see here I've done with my own two hands and my own tools. Now, I don't know how to weld, so for that and for critically precise implementations like re-gearing, I've relied on a good friend of mine here in Austin with years of experience (and his own shop) to help me out.
Finally, this project is my first real Jeep project - growing up we always had beaters (jeep and non jeep) we'd wheel in the mountains but nothing I would claim. In my late teens and early 20s I was more into drag racing, so its only been within the last couple years that I've come full circle back into the off-road space.
All that said, welcome, please enjoy, and thanks for taking the time to follow this build and my journey
Initial Setup: 2014 Sahara Unlimited
December 2013
3.6L Pentasar Engine w/ “NextGen” Dana 30/44 @ 3.73 Gearing
Modifications at the time of purchase
The Plan
The plan, quite simply, is for this to be a JK Experience capable rig that will also be street legal (non-trailered). The target is 37" tires, with the option to scale to 40" later in a way that my wife's 2 door can inherit the axles/suspension components if/when that bridge is crossed.
The theme for the jeep is based on a fictional character named Thanos from the Marvel Comics universe. I’m not planning on slapping a giant mural of the guy on the hood, but instead will be taking aspects of the character and personifying them in the Jeep. But even in the subtleties, I still plan on adding a few easter eggs here and there in the build that will be a direct nod to the character.
Finally, since I don’t have a piles of disposable cash laying about, or sponsorship, I’ll be building the Jeep up in phases, so things can/will change based on new information.
Phase 1 – Armor and Recovery
I purchased the Jeep as a dealer-built setup that had some useful modifications done to it that I knew I could later migrate onto a second 2-door Jeep that my wife would eventually buy. So, with a decent 35″ platform already in place, the first place to start was to get some protection around the vehicle, as well as some of the recovery gear and communication equipment.
So the laundry list for phase 1 looked like this:
Radio/Communication
Recovery/Misc
Armor
Phase 2 – Steering Components, Minimal Locker Investment, Cosmetic Upgrades - Completed!
Phase 2 was spent putting in time on the 35s, looking for gaps in on-board equipment, upgrading the front open diff with a cheap and reusable locker, and beefing up the steering components to prepare for Phase 3. Trying some of the more challenging trails at parks on 35s with the Unlimited wheelbase meant a lot more contact with things like my tie rod and underbelly components. Bashing up a few stock components while putting in the wheel time was part of the plan so I wasn't crunching "the good stuff" aftermarket components later on dumb mistakes.
Steering & Driveline
Misc/Cosmetic
Phase 3 – Scale to 37", Finish JKX Requirements- Completed! Applied! Update: SELECTED!!
This is the current phase I'm in now. I have the PR44 and EVO Long Arm kit fully installed (finally!).
Suspension
Drivetrain
Tires/Misc
Bonus
Phase 4 – Finishing Touches
The following phase will clean up some odds-and-ends that I would like to have done, but weren't really critical to build out Thanos to support applying for the JKX.
Lighting
Cosmetic
Phase 5 - One-Ton Swap
Drivetrain & Suspension
Wheels & Performance
Phase 6 - Double-tri rear & the push for 42s
December 2013
- 35″ Kelly Safari TSR Off-road Tires
- 17″ ProComp "Phantom" Series 5182 series Wheels.
- Teraflex JK Wrangler 2.5″ Suspension
- Aries Spare Tire Relocation Carrier
- Rugged Ridge Third Brake Light Extension
- Hypertech 752501 Speedometer Recalibrator
The Plan
Radio/Communication
- Cobra 29 LTD BT – Done, but ended up swapping out to a Cobra 75 WX ST for a much cleaner setup without having to mount a big radio. Also learned that the bluetooth feature was pretty useless already having UConnect.
- Firestik NGP LG4-M2-B CB Antenna– Done
- AntennaX 13" FM Antenna - Done
Recovery/Misc
- WARN Zeon 10s – Done
- TeraFlex Swaybar Quick-Disconnect System -Done, but later removed
Armor
- Poison Spyder Front Crusher Flares (Narrow) - Done
- Poison Spyder Read Crusher Flares - Done
- EVO MFG 1/4 Pounder – Done (Customized to fit Zeon winch)
- EVO MFG Rock Sliders – Done (Welded)
- EVO MFG LCA Skids - Done (Welded) - Retired w/old Axle
- EVO MFG Rock Skins – Owned but not Installed Yet
- Synergy Tie Rod – Done
- Synergy Drag Link – Done (Welded)
- TeraFlex HD Track Bar - Done
- Yukon Spartan Locker (Front/D30/3.73) - Done
Misc/Cosmetic
- Truck-Lite 7" Headlights - Done
- ARB Onboard Hi-Output Air Compressor - Done
- Bestop Safari Top - Done
- Bestop Tonneau Cover - Done
- Wayalife Windshield Banner/Side Icon Stickers -Done
- THANOS Hood Cowl Decals w/"Wrangler Omnipotent" replacement stickers - Done
- Factor 55 ProLink Shackle Mount - Done
Suspension
- EVO MFG Double-D Long Arm Suspension - Done
- (Front) EVO MFG Bolt-on LCG Coilovers - Done
- (Front) Evo/King Air Bump Stops - Done
- (Rear) EVO MFG 4" Plush Ride Coils - Done
- (Rear) Bilstein 5100 Series Shocks- Done
Drivetrain
- (Front) Dynatrac ProRock 44 Unlimited w/Reid Racing Knuckles, Synergy Ball Joints, Weld-on Drag Link Flip Bracket, 4.88 Gearing - Done
- (Front) RCV Axles - Done
- (Front) ARB Air Locker - Done
- (Front) Adam's Rear Driveshaft (1350) - Done
- (Rear) Yukon/Motive 4.88 R&P/Overhaul of stock D44 - Retired; D44 swapped for PRXD60.
- (Rear) Ten Factory 30 spline Chomo Axle Shafts - Retired; D44 swapped for PRXD60.
- (Rear) Dynatrac ProRock XD60 - 5x5 bolt pattern, Dynatrac HD Shafts, 4.88 gearing - Done
- (Rear) ARB Air Locker - Done
- (Rear) Adam's Driveshafts (1350) - Done
Tires/Misc
- Custom Weld-In Exhaust Loop Delete for LA Clearance - Done
- Nitto Mud Grapplers (37x13.5x17) - Done
- American Racing ATX Slabs (17x9) - Done
- Superchips Flashpaq - Done
- Extended/Steel Braided Brakelines - Done
- Hi-Lift 48" Jack - Done
- EVO MFG Tailgate Hi-Lift Jack Mount - Done, Retired to Nebula Jeep.
- EVO MFG Rear Corner Rockskins - Done
- EVO MFG Chromoly Sport Cage - Done
- Drake Offroad Fire Extinguisher Mount - Done
Bonus
- Poison Spyder Crusher Inner Fenders - Done, Retired to Nebula Jeep (replaced by EVO for C/O clearance)
- Excessive Industries GateKeeper in-cab tire carrier - Done
- PCI Race Radio (Icom F5021) w/Offoad Evolution channels - Done
- ACE GateKeeper Rear Rotopax & Highlift Jack Carrier + LP mount - Done
Lighting
- Rigid Industries Radiance Pods - Amber Accent - Front Flood - Done
- Rigid Industries "Capture" 11" Light Bar + GoPro - Done
- Lux Amber Accent Light for EVO sport cage center panel - Done
- 6x Lux Lighting Rock Lights - Done
- Rigid Industries "Radiant" White/Amber Corner Spot Lights - Done
- LED "Infinity Gems" - TBD
Cosmetic
- 4D Texas Tactical Spiderweb Shade - Done
- Blue Spiderweb Shade door skins - Done
- "Lady Death" Plymouth-style hood ornament - Need custom 3d work done.
- EVO MFG Vented Inner Fender for bolt-on coilover suspension - Done
- (Front) EVO MFG LCG Coilovers - Done
- (Front) EVO/King Front Airbump - Done
- (Front) Currie Anti-Rock Swaybar - Done
- (Front) 2008 Ford 350 Super Duty (SD60) - Done
- (Rear) 2005 GMC Sierra 2500 (10.5" 14 bolt) - Done
- (Rear)Currie Anti-Rock Swaybar - Done
- (Rear)Synergy 6" JK Rear Coil Springs - Done
- (Rear)Fox Racing 2.0 Series Shocks w/Res, 14" travel - Done
- MagnaFlow 17143 Offroad Pro-Series Cat-Back Exhaust - Done
- Redneck Ram Assist - Done
- KMC XD229 Machete Crawl Beadlocks - 17x9 in 8x6.5 - Done
- (Rear) GenRight 25gal Fuel Cell (stock gas tank delete)
- (Rear) Rock Kralwer Upper 4-Link Crossmember
- (Rear) GenRight Coilover Shock Mounts
- (Rear) X" King Coilovers (depending on available geometry)
- (Rear) King Air Bump Stops
- Transfer Case Upgrade (Rubi, Atlas4)
- 42" Nitto Trail Grapplers
- (Front) 3 Link?
