Phase 3 Part 1
Phase 3 was/is all about getting to the next level of suspension/tires in preparation for a JKX candidate build. Upgrading to 37" tires meant my existing TeraFlex 2.5" setup wasn't going to cut it, and I wanted to move into the EVO LA kit that would (at least in part) bridge over to a future coil-over setup wherein I at least get to retain the control arms.
Offroad Evolution "Double D" Long Arm Kit (Part 1)
March 2015
Back in March I took advantage of a RR4x4 sale where they were tossing Bilstein shocks with the EVO long arm kit, so off came the OE control arms. and TeraFlex springs and shocks.  By this point my wife had just got her own JK (2 door), so the old 2.5" TF lift actually re-purposed cleanly into becoming a 3" lift for her, and set her build up for my replaced 35" tires (pictured later).
As always, within a few days the shipment from Northridge arrived and it was time to get started:
This lift kit is not for the feint of heart, and "Dealing with Ambiguity" is absolutely one of those business terms that applies when taking on this project
I knew I had it coming through. I fully realized that the majority of folks with the kit probably had it installed at the EVO shop in Cali, or somewhere like Trail Jeeps, so I took it as a personal challenge to try and tackle this project on my own.
There are literally no instructions that come with the kit. I only had 2 external places to even reference when installing it - the original install thread on the JK/Wayalife forums from years ago where photos were taken of the first giveaway rig to have it installed, and then the product install notes by
Offroad Vegan.
I had to adapt both of those resources to the other significant challenge I was facing beyond my own inexperience: Not welding the kit in, and not having luxury items like a plasma torch or air tools. In truth, I knew that I had access to folks that
could help me if I needed it, so I approached it with the optimism and philosophy of at least not screwing anything up beyond repair
I decided to start with the front and just tackle what seemed like the bigger pita first.  I had to use my driveway due to height and side-accessibility constraints within my garage, so I used straps and stands to elevate the front end and suspend the axle as close to ride height as possible to minimize droop.  In this picture you can see that the first set of control arms have been removed in preparation for bracket cutting:
With the arms removed, the inner ears of the original UCA and LCA brackets have to be removed and ground down to make room for the new long arm bracket.  All the cool kids have plasma cutters that make this part easier. All I have is a a saw-zall. I went with Milwaukee "Diablo" series saw blades and found the shorter 4"
Steel Demon Carbide blades to work best for my approach.
The problem with using a saw was that the brackets are tight, curved, and run right up along the frame rails, which meant running a big hand held device that moves like a jackhammer took a wee bit of finesse to carve them out.  The second consideration is trying to cut as close to the welds as possible so that there's less material that needs to be ground down later. I ended up with an approach of cutting at the ear from two angles, and then bending the ear back to expose the last little bit needing to be cut:
I tried my best to keep the cuts as smooth and clean as possible, and then after the main ear of material was removed, come back in with a second arc of a more straight forward cut to scale the left over trim back closer to the frame/welds:
The next phase was to grind down the remaining bracket material to a smooth finish and clean up the bare metal with paint.  The grinding was by far the worst part - laying down under my jeep meant despite my best efforts I had lots and lots of metal dust raining down on me constantly, and since I started on the
passenger side, I had to be mindful of grinding angles that would send sparks towards the gas tank / fuel lines.  I ended up buying one of those heavy welder blankets and tacking it up to serve as both a protective layer for the tank, and as a drape over me to catch all the metal shavings.
My best grind pic (below) comes from the drivers side, where you can see the inner LCA ear is completely gone and smoothed down to the frame.  Slightly above it and to the right, you can see the remainder of the UCA mount post-cut and pre-grind.  Again, no air tools, so I was basically using an angle grinder from harbor freight with 4" flapper wheels:
After grinding and painting the exposed areas, there was a little bit of time spent dry-fitting the brackets and figuring out which OE bolts were being reused, where additional holes needed to be drilled, etc. My underbelly was pretty well "clearanced" (as Eddie puts it) so I had to do a few things to really get the frame brackets to wedge flush up against the frame and the tranny crossmember:
I basically had to loosen up both sides of the cross member so I could pre-run the bolts through the back of the bracket, and then use another jack to support the combined bracket/crossmember in place:
View attachment 157758View attachment 157759
After that it was a matter of center punching the places where new holes are required and getting them drilled out.  I actually avoided having to drop the gas tank and exhaust by using an elbow attachment with my drill. It was pretty late at night by the time I finally got everything fitted and bolted enough to crank everything down and get the first set of arms installed:
Last thing I went ahead and did for the night was do a test fit of the shock and spring. Shock was pretty easy but I had a couple issues with the Plush Ride coils (described later) so I snapped a pic of my progress and called it a night:
The next morning I dealt with the spring situation. The first issue was that the PR44 spring perch is drilled for center-screw bump stop pucks but the supplied set from EVO are the two-screw style. I was also wanting to just reuse the upper portion of the bump stop from TeraFlex but the snag there was that the top coil of the Plush Ride is too narrow to pass over the bump stop with it in place.
Since the combined length of the TF upper stop plus the lower puck that came with the PR44 was the same as what I would have gotten swapping things out and drilling, I ended up keeping the teraflex/dynatrac combo.  For the upper clearance issue, I popped out the upper stop, slipped the coil up into the perch, and then ran the bump stop up through the coil from the bottom and into the hole. For some reason I was having a hard time getting it to pop into place without marring the shit out of my coil with a traditional pry-bar, so I used one of the brackets that came with the lift kit as a stopper, and just compressed the axle upwards until it popped in:
The driver side went much easier since I had the confidence and experience of working through everything on the passenger side first. The only extra bit I had to reckon with was the exhaust loop.  I didn't have to drop my exhaust out, but the loop definitely had to go as there was no real way to get in behind it to cut/drill/grind/etc. So once again it was a quick stroke with the sawzall a few inches back from the header to get it out of there:
I originally wanted to preserve the loop after reading about all that back-pressure exhaust science, but this turned out to be a bust. I even tried the Rugged Ridge's exhaust loop relocation solution which uses a different bend direction to make it more of a horizontal loop than a vertical one, but it was just too much material to try to jam into the space and still have room for the long arms to clear.
I also didn't want to just use cheap flex-hose tubing like offroad vegan had used, so I ultimately did a little local research and found a muffler shop that had a solid custom exhaust guy, and he ended up bending me a nice S-pipe and welding it in for $90.  He made me feel better about uneven exhaust lengths and pointed out that Jeep may have been doing a bit of over-design in this area - pointing out that there are half a million dollar race tuned exotic cars that run uneven exhaust lengths and even back-pressure isn't enough of a concern for them. I guess well see; but the pipe he installed for me was nicely done regardless.  Here you can see it with the bracket/arms dry-fitted on to check clearance just before the final assembly:
This pretty much concluded the first half of getting the EVO long arm kit installed.  I needed to pause after finishing the front to be able to drive the Jeep to Discount Tire to do the big swap out of my old tires onto my wife's rims and the new 37s mounted/balanced onto mine. So I went ahead and swapped out the basic rear components just to balance things out as best I could to make room for the 37s, swapping in the rear plush ride coils and bilstein shocks, and swapped in the longer rear swaybar links.
Incidentally, I figured out a cool trick for squishing in the swaybar link bushings by using the lower shock mount and a bottle jack:
