14x1.25x100 sounds about right to me.
Forgot to add, I'm looking for the axle side rear lower.
I read somewhere maybe 14x1.25x100 or a 9/16x4.5. Just wanting to confirm.
I might actually have them and if not I go right past a place, Parkrose Hardwarea, everyday that will have them, in fact if your going to Ikea on Friday, you will be right by the place as well. I will check to see what I have when I get home and I'll let you know.
why do you need them longer? btw the lower bolts are M14x1.50x100.00
My brackets on my new axles are quarter inch thick and when you add the Rockstar skids to them they don't catch but one thread. Yeah I was getting ready to research it again cuz I went to the store and I could not find 1.25 in a 14mm. Only 1.50 and 2.00. thanx
Did you find them 4-1/2" long, usually only come in 100mm or 4" most places
I haven't yet, going to Fastenal next.
9/16 should be easy to find, i would try too use the 14mm though as the 9/16 is .040 smaller and allows for slop
I hope you are taking detailed notes of all the stuff you had to figure out with these axles. I think others would find it helpful. Just sayin.
