Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Brake Pedal Rattle
  1. #51
    Old Timer JeepFan's Avatar
    Oct 2011
    Palmenthal, CA
    2,952
    Quote Originally Posted by fgreatorex View Post
    I have a 2016 Rubicon with 3K miles on it the shift that became very loose so I brought it to the dealer turns out there was a recall on the shifter in a recall on the airbags I asked him to take a look at the pedal and they said it was normal but every time I hit a good-sized bump it's a rattle that sounds like it's coming from the steering column
    Typical dealer response. It's definitely not normal. If the rattle is really bothering you, I'd ask to discuss the issue with the service manager. If you're given the same answer, then you might want to call the Chrysler customer assistance center.
    Or just apply my fix and call it a day...😀
  2. #52
    Fresh Catch Alexander's Avatar
    Nov 2015
    Russia, Sakhalin island
    38
    That's the way we do it.
    1. Somebody wind up a couple of coils of office adhesive tape on the sleeves.
    2. My way is:
    Just an additional washer made from a material such as caprolon.
    There is almost no pedal rattling.
  3. #53
    Fresh Catch
    May 2017
    US
    4
    Great fix
    I have a 2016 Rubicon and the break pedal was making a loud noise when hitting a bump so I reached out and asked if anybody had the same problem and I got a reply to try Jeep fans fix and I am happy to say it worked great.
  4. #54
    Oct 2011
    Palmenthal, CA
    2,952
    Awesome! Glad this fixed the noise! 👍
  5. #55
    Nothing but a Thing Mybadjk's Avatar
    Dec 2016
    Elko
    1,787
    Anyone have the same rattle problem with the gas pedal?
  6. #56
    Nov 2015
    38
    Quote Originally Posted by Mybadjk View Post
    No. The gas pedal is tight enough.
  7. #57
    Fresh Catch
    Nov 2018
    Il
    4
    How?
    Hi,
    I'm a new owner of 2015 Jeep Sport and have this problem. Doing a search I came across this thread. I know it's old but I thought I would ask anyway. How did you guys, that did this, fix get two hands up there to get twist ties or clamps on the hose? I can get one hand up there and get the hose on but can't figure out how to get the zip ties on. I'm not a big guy but as as of yet I can't figure it out. Do I need to remove a panel or something?
  8. #58
    Oct 2011
    Palmenthal, CA
    2,952
    Quote Originally Posted by Toddo View Post
    Hi,
    Its definitely not an easy area to work around!
    I mostly used one hand to get the hose in place. With a little practice and extra long wire ties I was able to wrap the wire ties around the hose with one hand.
  9. #59
    Fresh Catch
    Nov 2018
    Il
    4
    Thanks for the reply. One more question. Do the zip ties simply keep the hose in place or do they perform a function in eliminating the rattle?
  10. #60
    Oct 2011
    Palmenthal, CA
    2,952
    The ties keep the hose in place. The tighter the hose fits between the pedal and bracket the better. I found the ties ensure the hose will not loosen over time.
