Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: CHECK ENGINE CODES : 2007-Up Jeep JK Wrangler
  1. #1
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    55,623
    Exclamation CHECK ENGINE CODES : 2007-Up Jeep JK Wrangler
    Thanks to the advent of technology, just about every single part on your new Jeep JK Wrangler is wired up to a computer. And, if anything goes wrong with any one of these parts, your Jeep’s computer will make a note of it and/or even let you know about it by illuminating a Malfunction Indicator Light (MIL for short or ‘check engine’ light) or icons on your dash. Unfortunately, the MIL or other icons won’t tell you a whole lot other than the fact that your Jeep is having some kind of a problem and unless you take your Jeep into the dealership or have a OBDII reader handy, you’re pretty much out of luck, right? Wrong. As luck would have it, the JK Wrangler’s come with a Diagnostic Trouble Code (DTC) reader built right into the dash and you can access them by following the 3 simple steps below. Once you have the DTC code(s) in hand, check it/them against the list below and you will be able to find out exactly what problems your Jeep is having.
    How to Read a DTC
    A DTC or Diagnostic Trouble Code is made up of 5 digits the first of which is one of the following letters:
    B - Body
    C - Chasis
    P - Power Train
    U - Network
    The 2nd digit indicates:
    0 - SAE
    1 - MFG
    The 3rd digit indicates:
    1 - Fuel & Air Metering
    2 - Fuel & Air Metering (Injector Circuit)
    3 - Injection Systems or Misfire
    4 - Auxillary Emissions Control
    5 - Vehicle Speed Control & Idle Control System
    6 - Computer Output Circuit
    7 - Transmission
    8 - Transmission
    The last 2 digits indicate:
    Fault (00-99)
    Instructions
    1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
    2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes as shown in the pic to the left. If your Jeep JK Wrangler has any logged in any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s) and check it/them against the list below to find out what they mean.
    3. If your Jeep JK Wrangler has not logged in any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
    Check Engine Codes List
    B1402 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1403 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1405 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1406 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1407 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1409 - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B140A - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B140B - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B140D - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B140E - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B140F - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1420 - AUDIO CASSETTE ERROR/INOPERABLE CASSETTE
    B1421 - AUDIO CD READ ERROR/INOPERABLE DISC
    B1422 - AUDIO DVD READ ERROR/INOPERABLE DISC
    B1423 - VES DVD READ ERROR/INOPERABLE DISC
    B1424 - IMPROPER DVD-WRONG REGION
    B1429 - RADIO DISPLAY HIGH TEMPERATURE
    B142A - RADIO UNIT HIGH TEMPERATURE
    B142C - VES VIDEO SCREEN DISCONNECTED
    B142D - AUDIO ANTENNA NOT CONNECTED
    B142E - GPS ANTENNA NOT CONNECTED
    B142F - SATELLITE RADIO ANTENNA NOT CONNECTED
    B1430 - SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
    B1460 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1461 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1462 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1463 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1464 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1465 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1466 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1467 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1468 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1469 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B146A - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B146B - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B146C - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B146D - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B146E - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B146F - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1470 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1471 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1472 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1473 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1474 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B1475 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B1476 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B1477 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B1478 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1479 - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
    B147A - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW
    B147B - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
    B147C - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
    B147D - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
    B1613 - PANEL ILLUMINATION CONTROL CIRCUIT LOW
    B1615 - PANEL ILLUMINATION CONTROL CIRCUIT OPEN
    B161A - COURTESY/DOME LAMP CONTROL CIRCUIT
    B161E - READING LAMP CONTROL CIRCUIT
    B162B - LEFT LOW BEAM CONTROL CIRCUIT LOW
    B162C - LT LOW BEAM CONTROL CKT HI
    B162F - RIGHT LOW BEAM CONTROL CIRCUIT LOW
    B1630 - RIGHT LOW BEAM CONTROL CIRCUIT HIGH
    B1633 - LEFT HI BEAM CONTROL CIRCUIT LOW
    B1634 - LEFT HI BEAM CONTROL CIRCUIT HIGH
    B1637 - RIGHT HI BEAM CONTROL CIRCUIT LOW
    B1638 - RIGHT HI BEAM CONTROL CIRCUIT HIGH
    B163B - FRONT LEFT TURN CONTROL CIRCUIT LOW
    B163C - FRONT LEFT TURN CONTROL CIRCUIT HIGH
    B163F - FRONT RIGHT TURN CONTROL CIRCUIT LOW
    B1640 - FRONT RIGHT TURN CONTROL CIRCUIT HIGH
    B1643 - REAR LEFT TURN CONTROL CIRCUIT LOW
    B1644 - REAR LEFT TURN CONTROL CIRCUIT HIGH
    B1644 - RIGHT STOP LAMP CONTROL CIRCUIT HIGH
    B1647 - REAR RIGHT TURN CONTROL CIRCUIT LOW
    B1648 - REAR RIGHT TURN CONTROL CIRCUIT HIGH
    B1663 - REAR FOG LAMP CONTROL CIRCUIT LOW
    B1664 - REAR FOG LAMP CONTROL CIRCUIT HIGH
    B166B - LEFT TRAILER TOW LAMP CONTROL CIRCUIT LOW
    B166C - LEFT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
    B166F - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT LOW
    B1670 - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
    B16B1 - LEFT STOP LAMP CONTROL CIRCUIT HIGH
    B16F8 - FRONT LEFT FOG LAMP CONTROL CIRCUIT LOW
    B16F9 - FRONT LEFT FOG LAMP CONTROL CIRCUIT HIGH
    B16FC - FRONT RIGHT FOG LAMP CONTROL CIRCUIT LOW
    B16FD - FRONT RIGHT FOG LAMP CONTROL CIRCUIT HIGH
    B17B8 - LEFT STOP LAMP CONTROL CIRCUIT OVERCURRENT
    B17B9 - RIGHT STOP LAMP CONTROL CIRCUIT OVERCURRENT
    B17BA - HEADLAMP LEVELING MOTOR CONTROL CIRCUIT OVERCURRENT
    B17BF - LEFT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
    B17C4 - RIGHT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
    B1801 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - CLUSTER
    B1806 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - TIPM
    B1934 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - CLUSTER
    B1935 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - TIPM
    B1A08 - RKE FOB 1 PERFORMANCE
    B1A09 - RKE FOB 2 PERFORMANCE
    B1A0A - RKE FOB 3 PERFORMANCE
    B1A0B - RKE FOB 4 PERFORMANCE
    B1A0C - RKE FOB 5 PERFORMANCE
    B1A0D - RKE FOB 6 PERFORMANCE
    B1A0E - RKE FOB 7 PERFORMANCE
    B1A0F - RKE FOB 8 PERFORMANCE
    B1A10 - RKE FOB 1 BATTERY LOW
    B1A11 - RKE FOB 2 BATTERY LOW
    B1A12 - RKE FOB 3 BATTERY LOW
    B1A13 - RKE FOB 4 BATTERY LOW
    B1A14 - RKE FOB 5 BATTERY LOW
    B1A15 - RKE FOB 6 BATTERY LOW
    B1A16 - RKE FOB 7 BATTERY LOW
    B1A17 - RKE FOB 8 BATTERY LOW
    B1A20 - PRE-ARM TIMEOUT
    B1A23 - RKE RECEIVER PERFORMANCE
    B1A24 - KEY NOT PROGRAMMED
    B1A25 - INVALID KEY
    B1A26 - MAXIMUM NUMBER OF KEYS PROGRAMMED
    B1A27 - SKREEM PROGRAMMING PERFORMANCE
    B1A28 - ECM MISMATCH WITH SKIM
    B1A29 - SKIM BASESTATION MISMATCH
    B1A3C - INTERNAL SIREN BATTERY
    B1A3D - SIREN BATTERY / LOSS OF POWER SUPPLY
    B1A3E - SIREN/ITM MISMATCH
    B1A3F - ITM ARMING SEQUENCE PERFORMANCE
    B1A48 - INTRUSION SENSOR 1 INTERNAL
    B1A5F - INTRUSION SENSOR 2 INTERNAL
    B1A6D - INTRUSION SENSOR 3 INTERNAL
    B1B00 - DRIVER AIRBAG SQUIB 1 CIRCUIT LOW
    B1B01 - DRIVER AIRBAG SQUIB 1 CIRCUIT HIGH
    B1B02 - DRIVER AIRBAG SQUIB 1 CIRCUIT OPEN
    B1B03 - DRIVER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
    B1B04 - DRIVER AIRBAG SQUIB 2 CIRCUIT LOW
    B1B05 - DRIVER AIRBAG SQUIB 2 CIRCUIT HIGH
    B1B06 - DRIVER AIRBAG SQUIB 2 CIRCUIT OPEN
    B1B07 - DRIVER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER
    B1B08 - PASSENGER AIRBAG SQUIB 1 CIRCUIT LOW
    B1B09 - PASSENGER AIRBAG SQUIB 1 CIRCUIT HIGH
    B1B0A - PASSENGER AIRBAG SQUIB 1 CIRCUIT OPEN
    B1B0B - PASSENGER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
    B1B0C - PASSENGER AIRBAG SQUIB 2 CIRCUIT LOW
    B1B0D - PASSENGER AIRBAG SQUIB 2 CIRCUIT HIGH
    B1B0E - PASSENGER AIRBAG SQUIB 2 CIRCUIT OPEN
    B1B0F - PASSENGER AIRBAG SQUIB 2 CIRCUITS SHORTED TOGETHER
    B1B54 - 1ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT LOW
    B1B55 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT HIGH
    B1B56 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT OPEN
    B1B70 - UP-FRONT LEFT SATELLITE ACCELERATION SENSOR INTERNAL
    B1B71 - UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR INTERNAL
    B1B72 - LEFT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
    B1B75 - RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
    B1B78 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT PERFORMANCE
    B1B79 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT LOW
    B1B7A - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT HIGH
    B1B7D - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT PERFORMANCE
    B1B7E - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT LOW
    B1B7F - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT HIGH
    B1B82 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR PERFORMANCE
    B1B83 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT LOW
    B1B84 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT HIGH
    B1B87 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR PERFORMANCE
    B1B88 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT LOW
    B1B89 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT HIGH
    B1B8D - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT LOW
    B1B8E - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
    B1B8F - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
    B1B93 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT LOW
    B1B94 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
    B1B95 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
    B1BA5 - AIRBAG SQUIB CONFIGURATION MISMATCH
    B1BA6 - OCCUPANT CLASSIFICATION UNDETERMINED
    B1BA7 - OCCUPANT CLASSIFICATION SYSTEM VERIFICATION REQUIRED
    B1BA8 - OCM SYSTEM OUT OF CALIBRATION/NOT CALIBRATED
    B1BAA - OCCUPANT CLASSIFICATION MODULE CONFIGURATION MISMATCH
    B1BBA - PASSENGER SEAT WEIGHT SENSOR SUPPLY CIRCUIT
    B1BBB - PASSENGER SEAT WEIGHT SENSOR INPUTS SHORTED TOGETHER
    B1BBC - OCS NEGATIVE SYSTEM WEIGHT
    B1BBD - OCM CURRENT CONFIGURATION TABLE UNPROGRAMMED
    B1BC7 - DEPLOYMENT DATA RECORD FULL
    B1C27 - LEFT SIDE SEAT THORAX SQUIB 1 LOW
    B1C28 - LEFT SIDE SEAT THORAX SQUIB 1 HIGH
    B1C29 - LEFT SIDE SEAT THORAX SQUIB 1 OPEN
    B1C2A - LEFT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
    B1C2B - RIGHT SIDE SEAT THORAX SQUIB 1 LOW
    B1C2C - RIGHT SIDE SEAT THORAX SQUIB 1 HIGH
    B1C2D - RIGHT SIDE SEAT THORAX SQUIB 1 OPEN
    B1C2E - RIGHT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
    B1C38 - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT LOW
    B1C39 - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT HIGH
    B1C3A - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT OPEN
    B1C3B - 1ST ROW DRIVER RETRACTOR PRETENSIONER CIRCUIT SHORTED TOGETHER
    B1C47 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT LOW
    B1C48 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT HIGH
    B1C49 - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT OPEN
    B1C4A - 1ST ROW PASSENGER RETRACTOR PRETENSIONER CIRCUIT SHORTED TOGETHER
    B2101 - IGNITION RUN/START INPUT CIRCUIT LOW
    B2102 - IGNITION RUN/START INPUT CIRCUIT HIGH
    B210A - SYSTEM VOLTAGE LOW (WCM)
    B210B - SYSTEM VOLTAGE HIGH (WCM)
    B210D - BATTERY VOLTAGE LOW (WCM)
    B210E - BATTERY VOLTAGE HIGH (WCM)
    B212C - IGNITION RUN/START INPUT CIRCUIT OPEN
    B212D - IGNITION RUN ONLY INPUT CIRCUIT OPEN
    B2142 - IGNITION OFF DRAW (IOD) FUSE NOT PRESENT
    B219A - IGNITION UNLOCK RUN/START CONTROL CIRCUIT OVERCURRENT
    B219F - IGNITION OFF DRAW (IOD) FUSE BLOWN
    B2201 - CALIBRATION MISMATCH
    B2204 - ECU CONFIGURATION MISMATCH
    B2205 - ORIGINAL VIN MISSING/MISMATCH
    B2206 - CURRENT VIN MISSING/MISMATCH
    B2206 - CURRENT VIN MISSING / MISMATCH
    B2207 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 1
    B2208 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 2
    B2209 - OCCUPANT RESTRAINT CONTROLLER INTERNAL 3
    B220A - OCCUPANT RESTRAINT CONTROLLER INTERNAL 4
    B220B - OCCUPANT RESTRAINT CONTROLLER FIRING STORED ENERGY
    B220C - OCCUPANT RESTRAINT CONTROLLER ACCELEROMETER 1 INTERNAL
    B220D - OCCUPANT RESTRAINT CONTROLLER ACCELEROMETER 2 INTERNAL
    B2212 - OCCUPANT CLASSIFICATION MODULE INTERNAL
    B2222 - SATELLITE RADIO RECEIVER INTERNAL
    B2224 - SKREEM INTERNAL
    B2229 - SKREEM INTERNAL - SKIM IMMOBILIZER
    B222A - VEHICLE LINE MISMATCH
    B222C - VEHICLE CONFIGURATION NOT PROGRAMMED
    B223B - VEHICLE CONFIGURATION MISMATCH
    B223C - INTRUSION TRANSCEIVER MODULE INTERNAL
    B223D - OCCUPANT CLASSIFICATION MODULE DTC PRESENT
    B2254 - COLUMN LOCK MODULE INTERNAL
    B2304 - WIPER PARK SWITCH INPUT CIRCUIT LOW
    B2305 - WIPER PARK SWITCH INPUT CIRCUIT HIGH
    B230D - REAR WIPER PARK SWITCH INPUT CIRCUIT LOW (STUCK LOW)
    B230E - REAR WIPER PARK SWITCH INPUT CIRCUIT HIGH (STUCK HIGH)
    B2323 - HEADLAMP WASHER MOTOR CONTROL CIRCUIT LOW
    B2324 - HEADLAMP WASHER MOTOR CONTROL CIRCUIT HIGH
    B2339 - HORN SWITCH STUCK
    C0077 - LOW TIRE PRESSURE
    C1404 - TRANSFER CASE RANGE POSITION SENSOR CIRCUIT LOW (TIPM)
    C1405 - TRANSFER CASE RANGE POSITION SENSOR CIRCUIT HIGH (TIPM)
    C1417 - FRONT DIFFERENTIAL CONTROL CIRCUIT LOW
    C1418 - FRONT DIFFERENTIAL CONTROL CIRCUIT HIGH
    C141D - REAR DIFFERENTIAL CONTROL CIRCUIT LOW
    C141E - REAR DIFFERENTIAL CONTROL CIRCUIT HIGH
    C1501 - TIRE PRESSURE SENSOR 1 INTERNAL
    C1502 - TIRE PRESSURE SENSOR 2 INTERNAL
    C1503 - TIRE PRESSURE SENSOR 3 INTERNAL
    C1504 - TIRE PRESSURE SENSOR 4 INTERNAL
    C2100 - BATTERY VOLTAGE LOW
    C2101 - BATTERY VOLTAGE HIGH
    C2207 - OFF ROAD ECU INTERNAL
  2. #2
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    55,623
    Check Engine Codes List Continued
    P0016 - Crankshaft/camshaft Timing Misalignment
    P0031 - O2 Sensor 1/1 Heater Circuit Low
    P0032 - O2 Sensor 1/1 Heater Circuit High
    P0037 - O2 Sensor 1/2 Heater Circuit Low
    P0038 - O2 Sensor 1/2 Heater Circuit High
    P0051 - O2 Sensor 2/1 Heater Circuit Low
    P0052 - O2 Sensor 2/1 Heater Circuit High
    P0057 - O2 Sensor 2/2 Heater Circuit Low
    P0058 - O2 Sensor 2/2 Heater Circuit High
    P0071 - Ambient Air Temperature Sensor Performance
    P0072 - Ambient Air Temperature Sensor Circuit Low
    P0073 - Ambient Air Temperature Sensor Circuit High
    P0107 - Manifold Absolute Pressure Sensor Circuit Low
    P0108 - Manifold Absolute Pressure Sensor Circuit High
    P0111 - Intake Air Temperature Sensor Rationality
    P0112 - Intake Air Temperature Sensor Circuit Low
    P0113 - Intake Air Temperature Sensor Circuit High
    P0116 - Engine Coolant Temperature Sensor Performance
    P0117 - Engine Coolant Temperature Sensor Circuit Low
    P0118 - Engine Coolant Temperature Sensor Circuit High
    P0121 - Throttle Position Sensor 1 Performance
    P0122 - Tps/apps Circuit Low
    P0122 - Throttle Position Sensor 1 Circuit Low
    P0123 - Tps/app Circuit High
    P0123 - Throttle Position Sensor 1 Circuit High
    P0124 - Tps/app Intermittent
    P0125 - Insufficient Coolant Temperature For Closed-loop Fuel Control
    P0128 - Thermostat Rationality
    P0129 - Barometric Pressure Out-of-range Low
    P0131 - O2 Sensor 1/1 Circuit Low
    P0132 - O2 Sensor 1/1 Circuit High
    P0133 - O2 Sensor 1/1 Slow Response
    P0135 - O2 Sensor 1/1 Heater Performance
    P0137 - O2 Sensor 1/2 Circuit Low
    P0138 - O2 Sensor 1/2 Circuit High
    P0139 - O2 Sensor 1/2 Slow Response
    P013a - O2 Sensor 1/2 Slow Response - Rich To Lean
    P013c - O2 Sensor 2/2 Slow Response - Rich To Lean
    P0141 - O2 Sensor 1/2 Heater Performance
    P0151 - O2 Sensor 2/1 Circuit Low
    P0152 - O2 Sensor 2/1 Circuit High
    P0153 - O2 Sensor 2/1 Slow Response
    P0155 - O2 Sensor 2/1 Heater Performance
    P0157 - O2 Sensor 2/2 Circuit Low
    P0158 - O2 Sensor 2/2 Circuit High
    P0159 - O2 Sensor 2/2 Slow Response
    P0161 - O2 Sensor 2/2 Heater Performance
    P0171 - Fuel System 1/1 Lean
    P0172 - Fuel System 1/1 Rich
    P0174 - Fuel System 2/1 Lean
    P0175 - Fuel System 2/1 Rich
    P0201 - Fuel Injector 1 Circuit
    P0202 - Fuel Injector 2 Circuit
    P0203 - Fuel Injector 3 Circuit
    P0204 - Fuel Injector 4 Circuit
    P0205 - Fuel Injector 5 Circuit
    P0206 - Fuel Injector 6 Circuit
    P0218 - High Temperature Operation Activated
    P0221 - Throttle Position Sensor 2 Performance
    P0222 - Throttle Position Sensor 2 Circuit Low
    P0223 - Throttle Position Sensor 2 Circuit High
    P0300 - Multiple Cylinder Misfire
    P0301 - Cylinder 1 Misfire
    P0302 - Cylinder 2 Misfire
    P0303 - Cylinder 3 Misfire
    P0304 - Cylinder 4 Misfire
    P0305 - Cylinder 5 Misfire
    P0306 - Cylinder 6 Misfire
    P0315 - No Crank Sensor Learned
    P0325 - Knock Sensor 1 Circuit
    P0335 - Crankshaft Position Sensor Circuit
    P0339 - Crankshaft Position Sensor Intermittent
    P0340 - Camshaft Position Sensor Circuit
    P0344 - Camshaft Position Sensor Intermittent
    P0401 - Egr System Performance
    P0403 - Egr Solenoid Circuit
    P0404 - Egr Position Sensor Rationality Open
    P0405 - Egr Position Sensor Circuit Low
    P0406 - Egr Position Sensor Circuit High
    P0420 - Catalyst Efficiency (bank 1)
    P0430 - Catalyst Efficiency (bank 2)
    P0440 - General Evap System Failure
    P0441 - Evap Purge System Performance
    P0443 - Evap Purge Solenoid Circuit
    P0452 - Evap Pressure Switch Stuck Closed
    P0455 - Evap Purge System Large Leak
    P0456 - Evap Purge System Small Leak
    P0457 - Loose Fuel Cap
    P0461 - Fuel Level Sensor 1 Performance
    P0462 - Fuel Level Sensor 1 Circuit Low
    P0463 - Fuel Level Sensor 1 Circuit High
    P0480 - Cooling Fan 1 Control Circuit
    P0481 - Cooling Fan 2 Control Circuit
    P0501 - Vehicle Speed Sensor 1 Performance
    P0503 - Vehicle Speed Sensor 1 Erratic
    P0506 - Idle Speed Performance Lower Than Expected
    P0507 - Idle Speed Performance Higher Than Expected
    P050b - Cold Start Ignition Timing Performance
    P050d - Cold Start Rough Idle
    P0513 - Invalid Skim Key
    P0522 - Engine Oil Pressure Too Low
    P0532 - A/c Pressure Sensor Circuit Low
    P0533 - A/c Pressure Sensor Circuit High
    P0562 - Battery Voltage Low
    P0563 - Battery Voltage High
    P0571 - Brake Switch 1 Performance
    P0572 - Brake Switch 1 Stuck On
    P0573 - Brake Switch 1 Stuck Off
    P0579 - Speed Control Switch 1 Performance
    P0580 - Speed Control Switch 1 Circuit Low
    P0581 - Speed Control Switch 1 Circuit High
    P0585 - Speed Control Switch 1/2 Correlation
    P0591 - Speed Control Switch 2 Performance
    P0592 - Speed Control Switch 2 Circuit Low
    P0593 - Speed Control Switch 2 Circuit High
    P0600 - Serial Communication Link
    P0601 - Internal Memory Checksum Invalid
    P0602 - Control Module Programming Error/not Programmed
    P0604 - Internal Control Module Ram
    P0605 - Internal Control Module Rom
    P0606 - Internal Ecm Processor
    P060b - Etc A/d Ground Performance
    P060d - Etc Level 2 App Performance
    P060e - Etc Level 2 Tps Performance
    P060f - Etc Level 2 Ect Performance
    P0613 - Internal Transmission Processor
    P061a - Etc Level 2 Torque Performance
    P061c - Etc Level 2 Rpm Performance
    P0622 - Generator Field Control Circuit
    P0627 - Fuel Pump Control Circuit
    P062c - Etc Level 2 Mph Performance
    P0630 - Vin Not Programmed In Pcm
    P0632 - Odometer Not Programmed In Pcm
    P0633 - Skim Secret Key Not Stored In Pcm
    P063a - Generator Voltage Sense Circuit
    P0642 - Sensor Reference Voltage 1 Circuit Low
    P0643 - Sensor Reference Voltage 1 Circuit High
    P0645 - A/c Clutch Control Circuit
    P0652 - Sensor Reference Voltage 2 Circuit Low
    P0653 - Sensor Reference Voltage 2 Circuit High
    P0685 - Auto Shutdown Control Circuit
    P0688 - Auto Shutdown Sense Circuit Low
    P0691 - Cooling Fan 1 Control Circuit Low
    P0692 - Cooling Fan 1 Control Circuit High
    P0693 - Cooling Fan 2 Control Circuit Low
    P0694 - Cooling Fan 2 Control Circuit High
    P0700 - Transmission Control System (mil Request)
    P0703 - Brake Switch 2 Performance
    P0706 - Transmission Range Sensor Rationality
    P0711 - Transmission Temperature Sensor Performance
    P0712 - Transmission Temperature Sensor Low
    P0713 - Transmission Temperature Sensor High
    P0714 - Transmission Temperature Sensor Intermittent
    P0716 - Input Speed Sensor 1 Circuit Performance
    P0721 - Output Speed Sensor Circuit Performance
    P0726 - Engine Speed Input Circuit Range/performance
    P0731 - Gear Ratio Error In 1st
    P0732 - Gear Ratio Error In 2nd
    P0733 - Gear Ratio Error In 3rd
    P0734 - Gear Ratio Error In 4th
    P0736 - Gear Ratio Error In Reverse
    P0740 - Tcc Out Of Range
    P0750 - Lr Solenoid Circuit
    P0755 - 2/4 Solenoid Circuit
    P0760 - Od Solenoid Circuit
    P0765 - Ud Solenoid Circuit
    P0841 - Lr Pressure Switch Rationality
    P0845 - 2/4 Hydraulic Pressure Test
    P0846 - 2/4 Pressure Switch Rationality
    P0850 - Park/neutral Switch Performance
    P0853 - Overdrive/tow Switch Input Circuit Stuck
    P0868 - Line Pressure Low
    P0869 - Line Pressure High
    P0870 - Od Hydraulic Pressure Test
    P0871 - Od Pressure Switch Rationality
    P0882 - Tcm Power Input Low
    P0883 - Tcm Power Input High
    P0884 - Power Up At Speed
    P0888 - Transmission Relay Always Off
    P0890 - Switched Battery
    P0891 - Transmission Relay Always On
    P0897 - Transmission Fluid Deteriorated
    P0933 - Line Pressure Sensor Circuit Performance
    P0934 - Line Pressure Sensor Circuit Low
    P0935 - Line Pressure Sensor Circuit High
    P0944 - Loss Of Hydraulic Pump Prime
    P0992 - 2/4/od Hydraulic Pressure Test
    P1115 - General Temperature Rationality
    P1128 - Closed Loop Fueling Not Achieved - Bank 1
    P1129 - Closed Loop Fueling Not Achieved - Bank 2
    P1273 - A/c Clutch Control Circuit 2 High (tipm)
    P1275 - A/c Clutch Control Circuit 2 Overcurrent (tipm)
    P128b - Tcm Power Control Circuit 2 Low - Tipm
    P128c - Tcm Power Control Circuit 2 High - Tipm
    P128d - Tcm Power Control Circuit 2 Open - Tipm
    P128e - Tcm Power Control Circuit 2 Overcurrent - Tipm
    P129c - Inverter Control Circuit High (tipm)
    P129e - Inverter Control Circuit Overcurrent (tipm)
    P1404 - Egr Position Sensor Rationality Closed
    P1501 - Vehicle Speed Sensor 1/2 Correlation - Drive Wheels
    P1502 - Vehicle Speed Sensor 1/2 Correlation - Non Drive Wheels
    P1572 - Brake Pedal Stuck On
    P1573 - Brake Pedal Stuck Off
    P1593 - Speed Control Switch 1/2 Stuck
    P1602 - Pcm Not Programmed
    P1607 - Pcm Internal Shutdown Timer Rationality Too Slow
    P1618 - Sensor Reference Voltage 1 Circuit Erratic
    P1628 - Sensor Reference Voltage 2 Circuit Erratic
    P1684 - Battery Was Disconnected
    P1696 - Eeprom Memory Write Denied/invalid
    P1697 - Emr (sri) Mileage Not Stored
    P1713 - Restricted Manual Valve In T2 Range
    P1745 - Transmission Line Pressure Too High For Too Long
    P1775 - Solenoid Switch Valve Latched In Tcc Position
    P1776 - Solenoid Switch Valve Latched In Lr Position
    P1790 - Fault Immediately After Shift
    P1794 - Speed Sensor Ground Error
    P1797 - Manual Shift Overheat
    P1897 - Level 1 Rpm Bus Unlock
    P2072 - Electronic Throttle Control System - Ice Blockage
    P2096 - Downstream Fuel Trim System 1 Lean
    P2097 - Downstream Fuel Trim System 1 Rich
    P2098 - Downstream Fuel Trim System 2 Lean
    P2099 - Downstream Fuel Trim System 2 Rich
    P2100 - Electronic Throttle Control Motor Circuit
    P2101 - Electronic Throttle Control Motor Performance
    P2107 - Electronic Throttle Control Module Processor
    P2110 - Electronic Throttle Control - Forced Limited Rpm
    P2111 - Electronic Throttle Control - Unable To Close
    P2112 - Electronic Throttle Control - Unable To Open
    P2115 - Accelerator Pedal Position Sensor 1 Minimum Stop Performance
    P2116 - Accelerator Pedal Position Sensor 2 Minimum Stop Performance
    P2118 - Electronic Throttle Control Motor Current Performance
    P2122 - Accelerator Pedal Position Sensor 1 Circuit Low
    P2123 - Accelerator Pedal Position Sensor 1 Circuit High
    P2127 - Accelerator Pedal Position Sensor 2 Circuit Low
    P2128 - Accelerator Pedal Position Sensor 2 Circuit High
    P2135 - Throttle Position Sensor 1/2 Correlation
    P2138 - Accelerator Pedal Position Sensor 1/2 Correlation
    P2161 - Vehicle Speed Sensor 2 Erratic
    P2166 - Accelerator Pedal Position Sensor 1 Maximum Stop Performance
    P2167 - Accelerator Pedal Position Sensor 2 Maximum Stop Performance
    P2172 - High Airflow / Vacuum Leak Detected (instantaneous Accumulation)
    P2173 - High Airflow / Vacuum Leak Detected (slow Accumulation)
    P2174 - Low Airflow / Restriction Detected (instantaneous Accumulation)
    P2175 - Low Airflow / Restriction Detected (slow Accumulation)
    P2181 - Cooling System Performance
    P2271 - O2 Sensor 1/2 Signal Stuck Rich
    P2273 - O2 Sensor 2/2 Signal Stuck Rich
    P2299 - Brake Pedal Position / Accelerator Pedal Position Incompatible
    P2302 - Ignition Coil 1 Secondary Circuit- Insufficient Ionization
    P2305 - Ignition Coil 2 Secondary Circuit- Insufficient Ionization
    P2308 - Ignition Coil 3 Secondary Circuit- Insufficient Ionization
    P2503 - Charging System Output Low
    P2504 - Charging System Output High
    P2610 - Pcm Internal Shutdown Timer Rationality Too Fast
    U0001 - Can C Bus
    U0001 - Can C Bus
    U0001 - Can C Bus Circuit
    U0002 - Can C Bus Off Performance
    U0010 - Can Interior Bus
    U0011 - Can Interior Bus Off Performance
    U0019 - Can Interior Bus(+)/(-) Circuit
    U0020 - Can Interior Bus Off Performance
    U0100 - Lost Communication With Ecm/pcm
    U0101 - Lost Communication With Tcm
    U0114 - Lost Communication With Final Drive Control Module
    U0121 - Lost Communication With Abs
    U0121 - Lost Communication With Anti-lock Brake Module
    U0121 - Lost Communication With Anti-lock Brake System (abs) Control Module
    U0126 - Lost Communication With Sas - Can C (steering Angle Sensor)
    U0141 - Lost Communication With Fcm
    U0141 - Lost Communication With Front Control Module (tipm)
    U0146 - Lost Communication With Central Gateway
    U0151 - Lost Communication With Occupant Restraint Controller (orc)
    U0154 - Lost Communication With Occupant Classification Module
    U0155 - Lost Communication With Cluster/ccn
    U0155 - Lost Communication With Cluster/ccn (skreem)
    U0161 - Lost Communication With Compass Module
    U0164 - Lost Communication With Hvac Control Module
    U0167 - Lost Communication With Intrusion Transceiver Control Module
    U0168 - Lost Communication With Vehicle Security Control Module (skreem-wcm)
    U0168 - Lost Communication With Vehicle Security Control Module (skreem/wcm)
    U0170 - Lost Communication W/up-front Left Satellite Acceleration Sensor
    U0171 - Lost Communication W/up-front Right Satellite Acceleration Sensor
    U0172 - Lost Communication W/left Side Satellite Acceleration Sensor 1
    U0175 - Communication W/right Side Satellite Acceleration Sensor 1
    U0184 - Lost Communication With Radio
    U0186 - Lost Communication With Audio Amplifier
    U0193 - Lost Communication With Traffic Information Receiver Module
    U0195 - Lost Communication With Sdars
    U0197 - Lost Communication With Hands Free Phone Module
    U0197 - Lost Communication With Hands Free Module
    U0199 - Lost Communication With Drivers Door Module
    U0200 - Lost Communication With Passenger Door Module
    U0415 - Implausible Data Received From Abs
    U0447 - Implausible Data Received From Central
    U1008 - Lin 1 Bus
    U1008 - Lin 1 Bus
    U110a - Lost Communication With Scm
    U110c - Lost Fuel Level Message
    U110d - Lost Communication With Security Siren
    U110e - Lost Ambient Temperature Message
    U110f - Lost Fuel Volume Message
    U1110 - Lost Vehicle Speed Message
    U1113 - Lost A/c Pressure Message
    U1120 - Lost Wheel Distance Message
    U113b - Lost Communication With Switch Bank Module
    U1149 - Lost Communication With Multifunction
    U1159 - Lost Communication With Asbs
    U1169 - Lost Communication With Intrusion Sensor 1
    U1170 - Lost Communication With Intrusion Sensor 2
    U1179 - Lost Communication With Intrusion Sensor 3
    U1403 - Implausible Fuel Level Signal Received
    U1411 - Implausible Fuel Volume Signal Received
    U1412 - Implausible Vehicle Speed Signal Received
    U1414 - Implausible/missing Ecu Network Configuration Data
    U1415 - Implausible/missing Vehicle Configuration Data
    U1416 - Implausible Security Siren Signal Received
    U1417 - Implausible Left Wheel Distance Signal Received
    U1418 - Implausible Right Wheel Distance Signal
    U1419 - Implausible Data Received From Ocs Sensor 3 - Left Front
    U141a - Implausible Data Received From Ocs Sensor 2 - Right Front
    U141b - Implausible Data Received From Ocs Sensor 4 - Left Rear
    U141c - Implausible Data Received From Ocs Sensor 1 - Right Rear
  3. #3
    Fresh Catch
    Join Date
    Apr 2014
    Location
    Philippines
    Posts
    3
    Unhappy How to do the procedure on a 2011 Jeep Wrangler JK Rubicon Unlimited v6 gas
    I have tried this procedure on my 2011 Jeep Wrangler JK Rubicon Unlimited for several times but failed. Nothing came out on my dash except that annoying "check engine" light that keeps showing up on my dash even there's nothing wrong with the jeep. Also, I have used the AEV PROCAL module to reset the problem but it keeps coming back. Can someone help me with my concern. Thank you very much.
  4. #4
    Join Date
    Aug 2013
    Location
    Fresno,CA
    Posts
    5,241
    Quote Originally Posted by SteelVise View Post
    You can try a hard reset by disconnecting your battery for a few minutes (10?). If that doesn't work you may have to take it to the dealership so they can plug it into their own computer to find the cause.
  5. #5
    Fresh Catch
    Join Date
    Jun 2013
    Posts
    28
    I did this this morning on my 12 2dr and it didn't work going from on to off either. It works going from on to acc and back 3 times. Try again but just the one notch instead of two. Unfortunately none had no code for why it's been temping between half and 3/4 on my gauge the past couple months, but checked and went straight to done. In glad however it wasn't having other problems. Don't mean to sound upset that it didn't pop out a few grand I need to spend in code fixes.
  6. #6
    Fresh Catch
    Join Date
    Apr 2014
    Location
    Philippines
    Posts
    3
    I just got my Superchips TrailDash from the mail and installed on my 2011 Jeep JK Rubicon. After setting up based on the Step-by-step instructions,
    Immediately reached for the Diagnostics for the check engine codes option and finally got the reading of U1418 - Implausible right wheel Distance Signal, and P0420 - Catalyst Efficiency (Bank 1) readings. Is there any section here which I could interpret these error codes and trouble shoot the specific problems? Anyone? Thanks
  7. #7
    Join Date
    Aug 2014
    Location
    Pine grove,pa & all the wrong places
    Posts
    91
    P0884
    anyone get this ?? Jeep went offline while driving, for what reason I do not know,,,,,I do know what the code entails, but why would it have dropped offline in the first place is unknown and while I was driving 65mph plus...any ryhmme or reason the jk would drop out of forward travel and the re engage or reset itself,,? anything come to mind...its showing no other trouble codes and no mil light....
  8. #8
    Hooked jims68's Avatar
    Join Date
    Jul 2013
    Location
    bismarck
    Posts
    187
    We had this happen to our T&C where the dash re-set while driving. Since then I have learned a lot about how the CanBus operates and most techs hate it! Here is a short breakdown. The TIPM or fuse box is like a cross roads and handles most orders like fuel pump on, window down and such but is also pass through for like your dash display. The ECM and antilock break module go to the TIPM and have connections together. The BCM, body control module, go back to TIPM. There really is no rhyme or reason to it! An example I was given you get a code pointing at a wheel sensor problem. You check sensor wiring and can't find anything so you replace sensor. Still get code. Take to dealer and they do the same thing. Come to find out it is the anti lock break module but it could of been the TIPM also. When you have modules that have to pass commands through them but don't control anything with this command and this module gets a problem like a bad connection or chaffed wire you get codes that point no where! That is why techs will shot gun stuff like this when it may be just a connection!
    OK with that all said I would re seat all the connections under TIPM. There are a ton of them. Just tip it forward after depressing lock tabs. There is lock tabs on each one then push locking arm forward to release each one. Look at each connector and make sure they are clean. If dirty blow out connector and also look for pins pushed back out of housing. If so pin was probably never seated so pin needs to be pushed into shell from the back till it seats or clicks in place. Look at harnesses to make sure none are rubbing or rubbed through. They are really packed underneath and make tight bends. Make sure to lock each one after re seating them.
    Now go over to the ECM/PCM, electronic control module or programmable control module in front of brake module. Should be three connectors if manual transmission, four for automatics, and reseat all of these. You should hear a pop when you pull each one of these off. They seal very tight so make sure they are clean and sealing properly.
    If this doesn't fix the problem you could also re seat connector on back of dash display. From there it could be a bad module or a bad connection on the two CanBus wires. This would entail chasing wires and a schematic of the system. I wish I had a good or easy explanation but these systems are very complex. I could be something as simple as maybe you put in an aftermarket radio and the module that was added to talk to CanBus, yes the communications ties through radio, has a loose connection. These two wires for CanBus are plus and minus and need a module to terminate each connection. If it opens up it is like pulling your network cable from your computer. If they get shorted or crossed bad things happen also. On a chevy you could pull each module then jumper the two wires for the CanBus to eliminate each module. But since Chrysler passes the CanBus through modules this may not work!
    Try the simple things first like re seating stuff and look for the obvious like rubbed wires. If you find exposed wires seal them back up. Broken wires solder and cover with two layers of shrink tube. Did you just add or changes something? Did this system rest happen after a big bump? Is anything else occurring like whippersnapper going for no reason? What year jeep? The 07's had quite a few issues and have several differences with there sister models. Don't try to switch modules with a buddies jeep! He may not be yor buddy for long! This could make the module un usable.
    Any questions let me know since I may have completely confused you!
  9. #9
    Join Date
    Jul 2013
    Location
    bismarck
    Posts
    187
    Forgot, lift + battery before doing ANY of the above things! This will ales reset the PCM and clear codes after about 15 minutes or just take + after finishing work and touch it to - before laying back down. This will drain the system down. Good luck.
  10. #10
    Knows a Thing or Two Desert Rose JK's Avatar
    Join Date
    May 2013
    Location
    Scottsdale, AZ
    Posts
    651
    Just tried to read the code as I had the 'MIL' engine light on... our 2013 JKUR w/ the 3.6 wouldn't show the bars or codes at first but kept playing with it and found that it worked with the combination of the 'ON' to 'ACC' (one click back, not two to 'OFF' as 'tinkering1' says above) three times at a faster pace worked for us. We found that the speed of the clicking for & back made a difference, a slightly slower pace didn't work but the faster did...either way....Thanks Eddie for providing this great info and the list of codes for us to use! You rock !
    2013 JKUR Billet
    EVO Enforcer w / 2.5 Kings
    PS Brawler front bumper
    Fuel Boost wheels, 37" Nitto T/G
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
