holliewood61
Now that we have a section here on Wayalife I figured I'd show off my junk.
Here's the specs.
81 cj7. Originally a 6cyl 3spd rig. Now sports a cammed up 304 with Edelbrock intake, long tube headers, MSD CDI box, coil, & dizzy. Also has MSD fuel injection. Trans is now a TH-400 with a Dana 20 t-case, both pulled from a J-truck. Axles are of the Dana 44 variety sourced from an International Scout. They are stuffed with Yukon 4.88's and Aussie lockers. Rolling stock is 37" Irok's on 15x12 simulocks (DIY bead locks are in the works). Recovery comes in the form of a Warn 8274 mounted on a modified TJ winch plate up front. I'm running home brew tube fenders and Genright armor the rest of the way around. Suspension is 4" Procomp springs up front, and 4" SuperLift springs out back. Future plans are a boat sided and comp cut yj tub, full cage, and 6" rear wheel base stretch.
Here's the specs.
