Results 1 to 8 of 8
Thread: Jeep Renegade Pinch Seam Trimming to Clear Bigger Tires Write-Up
  1. #1
    Oct 2011
    Carson City, NV
    56,308
    After installing our new 1.5" Daystar Lift and a set of 225/75R16 Cooper Discoverer STT Pro mud terrain tires on our Jeep Renegade Trailhawk, we found that we had a some some minor rubbing at about a 3/4 turn of the steering wheel. After giving things a closer look, we found that the rubbing was being caused by the edge of the front tires making contact with dimples on the plastic fender liners. Apparently, these dimples exist because of a pinch seam located directly behind the liners and if we were going to address the rubbing we had, we were going to have to do some trimming. In this short write-up, you'll get to see where the problem spots are and what you will need to do to do to fix it.
    What you will need
    • Phillips Screwdriver
    • 10mm Socket
    • Ratchet
    • Vice Grips
    • Angle Grinder
    • Cut Off Wheel
    • Flap Disc or Flat File
    • Heat Gun
    • Gloves
    • Eye Protection
    • Chassis Paint
    • Marker
    • Bungee Cord
    Instructions
    Here's a shot of the driver side front tire right where the edge of it makes contact with the dimple on the fender liner.
    Looking up behind the fender liner, you can see the pinch seam that the dimple is created for.
    1. While we used a lift to help make it easier to photograph this install, all you will need is a floor jack, a pair of jack stands and wheel chocks. To begin your install, simply place the wheel chocks up against your rear tires, lift the front of your Renegade until the tires are off the ground and then set it back down on jack stands positioned under the frame rails and just behind the front tires.
    2. Using a 17mm socket, remove the lug bolts securing the front wheels to your Renegade.
    3. Remove your wheels and then lay them flat under the frame rails of your Renegade for extra safety. You can now get a better look at the dimple you will need to address.
    4. Starting on the driver side of your Renegade, use a phillips screwdriver, remove the screw securing the fender liner to the base of the rocker trim.
    5. Using a 10mm socket, remove the 2 plastic nuts securing the rear half of the fender liner to the body of the Renegade.
    6. Pull the fender liner back then hold it out of the way using a bungee cord as shown.
    7. Using a marker, draw a line across the corner of the pinch seam where you will be cutting it off.
    8. Using a grinder with a cut off wheel, proceed to score the corner of the pinch seam where you drew your line.
    9. Grab the corner of the pinch seam with a pair of vice grips and then work it back and forth until it breaks free.
    10. Clean up the rough edge with a flap disc or flat file and then touch up the exposed metal with some chassis paint.
    11. Release the plastic fender liner from the bungee cord and then soften up the dimple by heating it up with a heat gun as shown.
    12. Once the dimple in the plastic is soft enough, press it inward. Being that the plastic will be very hot, you will need to be wearing gloves when you do this.
    13. Repeat steps 11-12 until the dimple is effectively sitting concave to the surface of the fender liner.
    14. Reinstall the fender liner and secure it in place with the 2 factory plastic nuts and 1 screw and then repeat the whole process on the passenger side of your Renegade.
    15. Reinstall your wheels making sure to tighten the lug bolts to 90 ft. lbs. of torque. Remove the jack stands and set your Renegade back on the ground. As you can see in this photo, you should now have enough clearance between your new larger tires and the fender liner to prevent any rubbing.
    That's pretty much all you need to do. I hope this write-up has been helpful to you and of course, if you have any questions, please don't hesitate to ask.
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    The Matrix
    31,955
    Sweet. I like the heat gun idea for the plastic.
    "And I sincerely believe with you, that banking establishments are more dangerous than standing armies; and that the principle of spending money to be paid by posterity, under the name of funding, is but swindling futurity on a large scale." -Thomas Jefferson.
  3. #3
    Oct 2011
    Carson City, NV
    56,308
    Thanks! It was either re-shape the plastic or trim it and I felt that this was the better way to go
  4. #4
    Old Timer Clifford33's Avatar
    Nov 2014
    Tennessee
    2,776
    Hey Eddie would love to see more pics of renny with his new shoes.
  5. #5
    Sep 2015
    The Matrix
    31,955
    Quote Originally Posted by Clifford33 View Post
    He's got 2 or 3 threads out there with the new tires on. I think he posted them last week.
  6. #6
    Fresh Catch
    Nov 2016
    Fort Collins, CO
    2
    Flex seal
    Hey I noticed you didn't bother welding the seam back together is that okay to skip?
    I thought maybe you could use some flex seal or something instead of just painting over it.
  7. #7
    Sep 2015
    The Matrix
    31,955
    Quote Originally Posted by carsonb View Post
    It's near impossible to weld a pinch seam back together. Metal is very thin, and the insulation inside is usually flammable. Something like flexseal would probably work fine. I used flexseal on all of my trimmed pinch seams on my WJ and it's held up.
  8. #8
    Oct 2011
    Carson City, NV
    56,308
    This ^^^^^
